Question about Pantech C120 Cellular Phone
C150 bluetooth busy, no turn off
Once I activate bluetooth and connect to a computer, I can not turn off the bluetooth.  I set it to off and hit OK and it says bluetooth busy.  I can not use the camera either, because of the bluetooth busy
  • 3 Answers
Try to press FN and B at the same time. that is the shortcut key to turn off and on bluetooth.
Posted on Apr 19, 2008
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 | Cell Phones
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
How to activate bluetooth on asus k55a
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 08, 2012 | Computers & Internet
I can't download the pictures off my pantech cell phone
You can connect your Pantech Link to your Windows 7 computer using the phone's built-in Bluetooth adapter. If your computer doesn't have a Bluetooth adapter bulit-in, you can connect the phone via a USB port. Once you connect your Link to your computer, you can use the phone as a modem, or transfer files back and forth between the phone and the computer.
Press the "Menu" key on the Pantech Link and select "Settings."
Open "Connectivity" and choose "Bluetooth," then "Activation." Set the option to "On" and press "Select."
Click "Back" and open "Visibility." Click "Show" and press "Select."
Click "Start" on the PC task bar, then click "Devices and Printers."
Right-click on your Bluetooth adapter and left-click "Bluetooth Settings." Check the box labeled "Allow Bluetooth Devices to Find This Computer" and click the "OK" button.
Click "Add a device" at the top of the screen. A new window pop ups, showing the nearby Bluetooth devices.
Highlight the Pantech Link and click "Next." A random number appears on the next screen.
Wait for the Pantech Link to prompt you for the number, then type the number into the phone and press "Select" to finish the pairing process.
Right-click on the Bluetooth adapter on the computer and left-click "Bluetooth Settings." Uncheck the "Allow Bluetooth Devices to Find This Computer" box and press the "OK" button. This prevents the computer from showing on other Bluetooth devices.
Regards.
Jun 18, 2011 | Cell Phones
How should i send or receive data from other mobile.
  1. Use a cellphone with Bluetooth (wireless connection), or even a USB connection (which is a computer port). These are all good ways to communicate with other devices.
  2. If your computer does not have the hardware for a Bluetooth connection, then buy the adaptor, sometimes called a 'dongle'. The adapter plugs into a USB port. It will be quite cheap, something like 10 to 20 American dollars. This adapter will have software for the connection process, which lets you transfer files from the computer to your phone, and the other way around.
  3. Make sure your computer is equipped with Bluetooth technology (either integrated into the machine or a USB dongle) and active.
  4. Turn on Bluetooth on your mobile device.
  5. Turn on your phone and go into 'Settings' in the Main Menu
  6. Keep going down until you find 'Bluetooth' (Sometimes it may be under 'Connectivity)
  7. Click on it and find 'Turn Bluetooth on' (or something similar) and press 'On'. You can now send and receive files. Once you receive a file, it will most likely be under 'Received Files'. This option can often be found in the Settings or Connectivity menu of your phone.
  8. Pair your computer with your mobile device by making both devices discoverable (also known as visible or unhidden) in the Bluetooth options. Once both are visible, search for Bluetooth devices on your mobile phone
  9. Locate the name of your computer in the results list and select it.
  10. Enter a 4 to 8 digit passcode of your own choosing and press continue.
  11. Once your devices are paired, you can send and receive files.
  12. There are several methods to send a file to your mobile device. One method is to copy the file from your computer, navigate to your mobile device (often found in My Computer or My Bluetooth Places) and then paste the file to the phone. Another option is to right-click on the desired file and select Send To --> Bluetooth Device --> (mobile phone's name).
  13. While the file is being transferred, you should see a progress bar on your computer and/or phone. Once the file is finished transferring, a message stating such should show up on your device's screen.
  14. Find the transferred file on your mobile phone by using the phone's built-in file explorer.
Oct 20, 2010 | Computers & Internet
Internet setting on samsung E1410
Hi there ,
It is possible to connect this phone (E1410) to the PC for Internet facility. You just need a bluetooth device.
I have successfully done it on my Airtel sim card using MO (Mobile Office) package.
Follow these steps-
1. Don't call the Airtel Customer Care to activate Mobile Office Setting. Because they will tell you that your handset does not support automatic MO setting.
2. In your phone go to browser and go to Browser Settings
3. Create a New Profile with the Name- Mobile Office
4. Home Page- http://www.google.com
5. Set the Proxy as- 202.56.231.117
6. Set the Port as- 9201
7. Bearer- GPRS
8. Go to Advanced Settings and type the APN- airtelgprs.com
9. Log in ID and password no need.
10. Recharge your your phone with any GPRS (Mobile Office) packages Rs.22 (200MB)/ Rs. 98 (2GB-30 Days validity).
12. From your mobile dial *567*11# (This is must)
13. Now your MO is activated. Now turn off your Phone, Remove the Sim card and turn on again.
Please cancel the mCheque msg. if it appears after restarting your phone.
14. In your PC -Install the Bluetooth Driver.
15. Right click on the Internet Explorer-Properties-Connections
16. Select the Bluetooth DUN Connection
17. Click on Settings
18. Set the proxy-202.56.231.117 ;port as-9201
19. Click -OK, Apply - OK.
20. Now go to control pannel and double click on Phone and Modem options.
21. Click on Modems tab.
22. Select Bluetooth DUN Modem
23. Click on Properties
24. Click on Advanced Tab
25. In the Extra Initialization Command box paste the following command line-
AT+CGDCONT=1,"ip","airtelgprs.com","",0,0
26. Click OK, then Apply-OK.
27. In your phone turn on the Bluetooth
28. Insert your Bluetooth Device in Your PC and connect Your phone through the Bluetooth software
29. Click- Bluetooth Dial up Networking Service on your Bluetooth Software
30. The dialing number is *99#
31. Remember the connection may not done for the first time. So you may need to try more and more. Because the Airtel lines are always busy. Sometimes you may need to unplug your Bluetooth device and
exit your BlueSoleil from the Quick Lunch bar and Restart the Procedure. Remember this is the only procedure
for Airtel (MO) users. Try and Try and if it is connected the open any browser (I prefer- Mozilla Firefox) and open- www.google.com. Remember in some cases, it shows a false connection and the website will not open.
In such cases, Disconnect your Dial Up connection and Re-connect it. If any message apper in you phone, then exit it.
32. To check Mobile Office Package balance and validity dial- *123*10#
32. Remember I am sending this information to the internet via Connecting my E1410 mobile to my PC using Bluetooth device.
33. If you are successful, please say a little word-"Thanks
Sep 26, 2010 | Samsung Lands Phones
Unable to access internet in samsung E1410 mobile
Hi there ,
Follow these steps-
7. Bearer- GPRS
33. If you have any Problem please inform me in my mail- riteshgohain@rediffmail.com
34. If you are successful, please say a little word-"Thanks yar
Feb 19, 2010 | Samsung Cell Phones
I have a LG Vu and I want to use the bluetooth setting to download photos into iPhoto. How can I do this? I have tried and tried to no avail, my imac book still shows no connection. Help me please!
What you do is find the bluetooth symbol at the top of your screen (the background) then go to SETTINGS and then to DEVICE VISIBILITY (should be the very top) hit the ON choick then OK for other bluetooth devices to recognise it. then go back to the MAIN BLUETOOTH MENU (just hit back button) and go to SEARCH NEW DEVICE (second one down) but make sure you are in the same room as your computer to have your phone connect with the computer. That should then find your computer and then REQUEST TO PAIR (just touch the name of your mac) and then ENTER THE CODE (should be four zeros if you didnt change it and do the same thing on your mac then after that just select the photo you want to send and hit SEND VIA BLUETOOTH and select your mac
Jun 29, 2009 | LG KU990 Viewty
Activating bluetooth
hi.
lahansseynar,
first you have to download the driver of the bluetooth device from the dell driver &utilities cd & then u can recive and send diffrent items to another bluetooth device.
Dec 21, 2008 | Dell Vostro 1700 Notebook
Delete demo files on Sandisk c150?
The demo songs still don't show up when I select "Show hidden files/folders". I had go to Menu->Settings->Format, and proceed with formatting it to get the demo songs off my Sansa c240 (This will delete all songs/files).
Dec 31, 2006 | SanDisk Sansa c150 MP3 Player
Pantech C120 Cellular Phone Logo
140 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
