Question about Lexmark Z645 InkJet Photo Printer
Lexmark Z645 Printer
I have added the above printer to my PC but all I get when trying to print is a box saying:-
Communication Not Available
The Printer Cannot communicate with the computer.
Try these solutions:
Disconnect and reconnect the USB cable
Disconnect and reconnect the printer power cable
Restart your computer
I have done all the above but all I get is the above message!!!!
Help
Garry
  • Anonymous Feb 22, 2008
    Fe. 21,2008 I recently made a lexmark phone call today and the problem I was having had been solved as for printing offline but when I try to print from the internet I only receive the address at the top of the page and then I receive a voice notification of a printer problem. I have check the blinking flash count and their is not a paper jam, or a usb problem. I was told to go on line and to the lexmark support center to have this problem check to be corrected. I would like to have the support to restore any nessecary corrections that can be made. PLEASE!
  • Anonymous Mar 11, 2008
    I also tryed to connect my pc ( presario pc ) to the printer the box appeared on the upper left hand corner said communication not possible, so I
    disconnected and reconnected the usb cable
    disconnected and reconnected the power cable
    restarted computer
    Need help
I would suggest to unplug the USb cable and uninstall the software. Reinstall the software with the printer unpluged.
After you have done this turn the systen off, plug in your printer and boot the system with the printer on. A notice will come up saying "Found New Hardware". The system will install the drivers and all should be good. If you have changed the USB port you set it up on you will have the same problem again.
Posted on Mar 25, 2008
I have a problem of Lexmark Z645 Printer i want a software of this .
Posted on Mar 02, 2008
Just hooked an old lexmark 3300 printer to my windows vista. When printing it says communication not available
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ffZS77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X1270 All-In-One InkJet Printer
Hi, I own a Lexmark z645 printer and an airport express . Everything is installed but it doesn't print anything. Is this printer compatible with APE? Thanks
What is the operating system installed on your computer?
Note: The Lexmark Z645 printer only works on Windows operating system. Unfortunately there are no Lexmark Z645 printer drivers available for Macintosh operating system.
Jul 28, 2011 | Lexmark Z645 InkJet Photo Printer
I installed a new lexmark Z645 in my HP Compaqnc6120 llaptop. While printing its giving message 'Communication Not Available- the printer cannot communicate with the printer'. i have disconnected and...
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs
Jul 01, 2009 | Lexmark Z640 InkJet Printer
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Apr 13, 2009 | Lexmark Z645 InkJet Photo Printer
Won't install
my pc windows98 ,ram 64 MB, iwant to install Lexmark Z645 InkJet Photo Printer driver install but whyyyyyy ?
Aug 24, 2008 | Lexmark Z645 InkJet Photo Printer
Won't Print
I also have a Z645 and have had it now for almost a year...love it's performance but now all of a sudden it only prints certain things...duh! I don't know if any of you that have problems went to the sdolution center for Lexmark but on there ...there an upgrade to your printer, which is not is a section that says you MAY need to install an upgrade which sometimes corrects the problem UNLESS of course you do as I do with my "other" lexmark and they tell you that there no longer is any updates so in that case you are S.O.L....basically you need to buy a new printer......I am gonna call tech support tomorrow for my problem but getting the upgrade MAY help you others....good luck!
Jun 14, 2008 | Lexmark Z645 InkJet Photo Printer
Printer
Try this:
1. From Control Panel > Printers... delete all printers.
2. Unplug the usb cable.
3. Re-boot
4. Install software
5. Plug in usb cable.
Hope that works for ya...
Geno
Feb 27, 2008 | Lexmark Z645 InkJet Photo Printer
Printer and computer arent' communicating
no, a missing black cartridge is not the problem. If other USB devices (do you have a usb mouse or camera) work on your HP, you must try the printer on another PC to test the printer is functional. Many outlet stores like Best Buy will allow you to bring in your printer to test it communicating.
Sep 03, 2007 | Lexmark Z645 InkJet Photo Printer
Lexmark Z645 InkJet Photo Printer Logo
171 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
