Kenmore elite washer problem
Hello, my washer stops in the middle of the cycle and doesn't drain the water. The display shows: Ld, or another time Fl. Do you know what it means? I appreciate your help I have a Kenmore Elite HE washer. Occasionally get an F51 error. Won't go away til I stop and restart it. Bought it refurbished and did not come with a manual. Help. Thanks
  • jess65 Feb 16, 2008
    Thanks for trying. Am having a tech come out and look at it.
    President:
  • 1,294 Answers
Click on kenmore (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
Posted on Feb 12, 2008
  • prem mathew Feb 12, 2008
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to look into.
My washer stops in the middle of the cycle what does this mean Flashes LD Error
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Displays ld
Hi, how are ya?
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Thanks for using Fixya
Oct 16, 2007 | Kenmore 27032
Washing Machines Logo
344 people viewed this question
Top Washing Machines Experts
