Question about Jenn-Air JJW9527C Expressions Collection Electric Single Oven
Jenn air oven display
The green digital display that reads the time, temp and timer modes has gone dim. can I fix this myself? or do I need a repairman? The front buttons are all built into the oven and flat. if I cant read the display is difficult to gage time & temp. Thanks
  • 4 more comments
  • Anonymous Feb 20, 2008
    Log on to this site :)
  • Anonymous Mar 02, 2008
    I have same problem light is dim can't read display Jenn-air modelJJW9530C
  • Matt
    Matt Apr 15, 2008
    same as your problem. model ww27430w
  • steve burkes Jul 14, 2008
    temp display completely dim. the time is almost completely dim.
  • haynes417 Mar 30, 2009
    Light doesn't work or is very dim. Broiler and timer functions also don't work. Mine is the Jenn-Air JJW9527AAW model.
  • JOHN ROTHROCK Oct 16, 2013
    this is the second time i have had a problem with the jenair oven display. jr lexington nc
The digital display on my jenn-air oven, model jjw9527c...has gone completely out. i am very efficient in wiring and electronics and would have no problem fixing it myself, just not sure which parts i need to order. Please return this with a solution, holiday season is very close.....thank u
Posted on Sep 11, 2008
On the jenn-air w27400w display that is dim or non-existent. Replaced three of the electrolytic caps on the display board. I used two 470uF @35vdc and one 100uF @50vdc purchased from Radio Shack for $4.42. the display came alive with it's original brightness. Any electronic tech or handy Ham Radio Operator should be able to replace the caps easily.
Posted on Feb 05, 2009
Problem Statement:
Approx 5 year old Jenn Air Oven display gradually dimmed over time and eventually became unreadable.
Root Cause:
The problem, in my case, was the VFD (Vacuum Fluorescent Display) itself which cannot be separately removed from the printed circuit board (pcb). I verified this was not a power issue by checking that 5V was present on pin 21 of the HD40318S 4 bit microcomputer. I got the data sheet for the controller on line. On checking further on VFD reliability on the internet, wikipedia explained the physics of the VFD construction and how this technology is subject to "fading" over time.
Solution:
I found a replacement assembly at RepairClinic.com. Assembly part# 695197, "Electronic Clock Control" cost $180.70+shipping. It worked. However, there is a caution here. The replacement assembly had 2 subtle differences. The pcb replacement was made using SMT (Surface Mout Technology), whereas the original was made using the older PTH (Plated Through Hole technology). This wasn't an issue because schematically both assemblies were the same BUT one of the three connectors was different. I had to improvise here and make a pass through using IC pins from an IC wire wrap assembly I had and did this without compromising warranty.
Posted on Nov 13, 2008
Change the capacitor at C3 . 68mf 35volts. worked for me. Ordered from digikey. part # P12926-ND or P10292-ND and cost all of .25 cents. Shipping was 6 bucks. email me if you need help. toysrme@sbcglobal.net
Posted on Jul 24, 2008
Temporary solution, rapping on the display brings it back to normal for about a day. Certainly not a permanent fix, though.
Posted on Mar 03, 2008
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
The light and temperature display are very dim and hard to see.
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
Steve Patterson
303-256-8494
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air JJW9527C Expressions Collection Electric Single Oven Logo
940 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
