Question about HP Compaq Presario V2000 Notebook
I am having problems
I can not get my laptop to come on I am recieving a pxe media text failure message and then it shuts off and on
  • 39 Answers
When I first read this I was sure that PXE was turned on in your BIOS...which still may be the case. It's trying to boot from a NIC card.
If you have recently serviced this laptop...replaced the hard drive, etc...then perhaps the keyboard cable has come loose.
Let me know...if it is none of those.
Good Luck my friend.
SeekPCRepair
Posted on Feb 09, 2008
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
PXE-E61 Media test failure
See this on-line thread from other users. I'd be leary about the posts that advocated hitting the laptop...
http://www.nocrash.com/ncbbs/msgs/3247.shtml
Portable computers can suffer from bad connections easily, so the first thing you should check are that all cables and other connections are tight and seated firmly.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
HP Compaq Presario V2000 Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
