Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cycles all the way thru, stays stuck at 1 minute
I had this problem for a long time too, then I read the maual once I found it...and it says that if you have a water softeer, you need to use very little detergent, or the machine will continue to run, because there is still soap on the dishes. Also, I have the dishwasher with the stainless steel interior and it says that yo need to use powder detergent, not liquid and lastly you have to use a rinse agent. Once I corrected all three of the things I was dong wrong, my machine worked perfectly. I was about to get rid of the machine, but I am glad I finally sat down with the manual.
I hope this helps you.
Posted on Feb 10, 2008
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher error code c1
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Bosch shu66c02uc dishwasher has much longer cycle run times than it did the first 4 years we had it, also stays stuck on 1 or 2 minutes remaining for 30 minutes or more. Just doesn't clean any more.
Sounds like the filter is clogged. If you can and want to try to fix it yourself open door all the way after unplugging it or disconnecting power. Look under the top and you will find screws that you can take out and pull cage out. Then look at all of the drains, filter(s) and see if anything is clogged.
Jan 05, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Cycle runs forever
Th Bosch units are prone to circuit board failure and this is the common symptom. If you are electronically inclined go the and search Bosch for test codes to pinpoint the issue.There is an online picture of the faulty relay solder joint I repaired mine and a neighbors, Bosch will in some cases supply parts at no charge and they do not recommend repair, however IMHO it is a repairable cold solder joint very visible on the board. If you are good with needle tip soldering iron you are in luck
Sep 07, 2009 | Bosch SHU5315UC Dishwasher
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
287 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
