Question about Olympus Camedia C-5050 Zoom Digital Camera
LCD Screen Black/Blank. ? ? ?
My Olympus C5050 zoom, will power on & display all of the menus etc, but when I try to put it into any shooting mode & use the quick view function the LCD is totally Black/Blank.
However it does to all intents & purposes take a photo & flashes etc, but yet again, when you go back into playback mode, it will show you the number of photos you've taken or should I say attempted to take, but nothing whatsoever on the display.
Can somebody please help or advise me.
Also can anyone tell me or post me a link where I can get the PROPER CAMEDIA software to connect to my pc & also to update my firmware on the camera etc.
Thanks in advance
Martin
(marvin8862@hotmail.com)
    Problem Solver:
  • 7 Answers
Perhaps you have quick view turned off in the setup menus. There's no way the CCD is the problem as the camera takes pictures.
Posted on Apr 08, 2008
  • 593 Answers
Bad CCD, Olympus recall. Look online for instructions. No way around it.
Posted on Feb 25, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
I tried to shoot the solar eclipse with an X-ray film about 1 foot away from my FE 320 olympus camera. Thereafter the pictures display was reddish in colour for a while. After about 2 hours the display...
I would suggest a new camera...and never do that again. There's a reason we don't look directly at an eclipse...your camera's sensor doesn't have healing abilities.
Feb 25, 2010 | Cameras
Olympus C5050
That's a crying shame.  I believe that spares are no longer available for this unit (which is, IMHO, one of the very best prosumer digitals ever built).
Your best bets would be to take it to a local camera service center, or, to look on eBay for a used C5050 or C8080 (8MP with most of the same capabilities and some improvements, but, not quite as good an aperture) for a very reasonable price in good condition.
I know that's less than ideal, but, after a great deal of research on a similar problem with my C5050, that's where I ended up.
Sep 22, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
How to replace LCD monitor/screen in an Olympus C5050 camera
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
May 06, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
In shooting mode the lcd screen is black
Olympus says this is a bad image processing chip. They will replace it at no charge if you are still within the year warranty period. They require proof of purchase i.e. receipt, copy of charge card statement, copy of warranty card, etc. Contact them for further information on how to return it.
Nov 16, 2007 | Olympus FE-210 Digital Camera
Olympus C-8080 LCD wont work
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Apr 07, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
LCD Monitor on and the electronic viewfinder
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
Difference between the D-400 Zoom and the D-450 Zoom
The D-450 Zoom is an improved version of the D-400 Zoom. Both models have the following features: •1.3 megapixel resolution •3x optical zoom lens - 2x digital telephoto •Stream-lined compact form design •Automatic focus, metering, and white balance •Built-in, pop-up electronic flash •Real-image optical viewfinder •LCD monitor •Buffered RAM memory; burst shooting •Video output to TV •12-second self-timer •8 meg SmartMedia included. Larger capacity cards available. In addition, the D-450 Zoom has the following features: •A larger buffered RAM memory permits rapid shooting (real-time shooting without having to wait for the image write) and a true sequence shooting in more quality modes: Memory Card Storage Capacity Shots Frames per second Quality Mode 10 2.0 SQ 8 0.8 HQ 4 0.8 SHQ •A new high-resolution glare-free LCD monitor screen that can be easily viewed at any angle and even in bright sunlight. The new monitor also uses less power •Automatic ISO adjustment from ISO 160 to 640. Manually selectable ISO 160, 320, and 640 •New Slow-Synchronization flash mode which enables the use of the flash on shots requiring long exposure (such as night time photography) •Image playback now includes an easier to use index mode of 4, 9, or 16 images. A 3x magnification inspection mode allows easy viewing of image detail •Overall power efficiency has been improved. 1.5 to 2 times more battery life compared to the D-400 Zoom •D-450 Zoom comes in a Champagne Gold finish NOTE: The D-450 Zoom digital camera does not include the Olympus FlashPath floppy disk adapter (which was included with the D-400 Zoom). The FlashPath adapter is available as a separate accessory.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Olympus Camedia C-5050 Zoom Digital Camera Logo
219 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
