Question about Garmin StreetPilot c340 GPS Receiver
GARMIN DOESNT PICK UP SATELLITES
EVEERYTIME I TURN IT ON IT TAKES 20 MINS TO ACQUIRE SATTELITE
  • 99 Answers
You have a problem with your internal antenna. You can easly reslove this by hooking up an external antenna, and watch it go from 20 to two mins.
Posted on Feb 09, 2008
I asked this question when i switch my garmin 200w on it takes 15-20 mins to find satellites any ideas on how to fix this problem Got this answer first time, when you turn on your GPS...
Changing settings on the device will not fix the problem. The problem is either:
1. The GPS is defective.
2. The GPS is not in a line of sight with the GPS satellites. This can be fixed by re-positioning the unit in your vehicle. You can also take the vehicle out of the car and let it find the satellites and then put it back in your vehicle. If reception is blocked in your vehicle, that won't help, but if reception is just iffy, then it will.
Sep 16, 2017 | Garmin GPS
When i switch my garmin 200w on it takes 15-20 mins to find satellites any ideas on how to fix this problem
first time, when you turn on your GPS in new position, it's normal. but if second time turn on, it still be same thing, that's problem. please make every setting back default to test
Mar 18, 2011 | Garmin nuvi 255W GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
Frequently loses satellites.
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor satellite reception, loosing satellites, and taking a long time to acquire satellites are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Sep 20, 2009 | Garmin n?vi 265WT Car GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
110 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
