Question about Kogi L7CH Monitor
Kogi monitor ... it goes blank
I recently got Kogi L5QX 15" LCD monitor. When I first plug in everything it was working perfect then about 30 minutes after it went blank. (I was changing the brightness and contrast) , just white screen.
What should I do? my computer is Dell.
Thanks
Where can I buy the power cord for my KOGI L5QX?
Posted on Mar 04, 2008
2 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Goes Blank
ok ... i answered your last post as well. is there a reset button on it. the few lcd monitors i've worked on required pressing the far left hand button on the front to reset it.
Robert
Posted on Aug 28, 2008
Picture is too tall - how do you make it shorter?
The buttons on the front of your monitor will have a set up. When you get into setup mode there will be a bunch of symbols. Use the other buttons to scroll around to the correct one. It will be the one with the arrows pointing to the top and bottom of the screen.
There should be either a + - button or something like that. Just push the one that makes the screen shorter to the desired height.
cheers and good luck
Nov 21, 2009 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Kogi L5QX monitor is not centered,
I tried the suggestion on one of your posts. Simultaneously, pushing in the two middle buttons on the front of the monitor. I figured it out from there. Thank you!
Oct 30, 2009 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
There is an internal crack in the screen.
No fear there, you have likely only cracked the protective glass covering and not the display itself, if the display itself was cracked then you would either lose your video or have a severe distortion in the area of the crack.
So dont sweat it!
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Blank screen
try to reinstall the drivers of your video card while you are in safe mode.
Aug 25, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Does not work with new desktop
All you have to do is change the monitor resolution to that mode. That's probably the maximum resolution you will get with that monitor, video card, and comptuer.
Aug 13, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
I need a power supply for my Kogi L7EH-TA monitor
I would not recommend this because my monitor will probably burn up from doing this but; I just lost my power supply last night and I took a power cord from my seagate external 500 GB hard drive which has the same pin size plug in that goes into the monitor and plugged it directly into the wall. I assume that the external hard drive uses the same ac to dc converter although it looks just like a cord with no inverter capabilies. Not sure of the amps though and this could burn up the monitor completely. Works for now.
Mar 04, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Goes Blank
Robert
Feb 09, 2008 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Green light on - screen on briefly, then goes black.
Replacement is probably the only option at this point. It would cost more to fix than it would be worth new. Try going to: www.tigerdirect.com www.newegg.com They are usually running cheap specials on monitors.
Aug 26, 2007 | Kogi l5qx-ta ko 15" Flat Panel LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Kogi L7CH Monitor Logo
131 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
