I have no picture or sound on my RCA REAR PROJECTION TV?
I have a 1994 rear projection RCA TV ModelP46727BA that does not have picture or sound, can you help?
Ninistaun
    Genius:
  • 3,422 Answers
ONE: This is an RCA set. Not a good thing - in my humble opinion. They are not a reliable brand.
TWO: The set is old enough that you should always keep in mind the question of repair or replace. Since it is an expensive set, it should return the investment to you; on the other hand, if the cost of maintaining it gets out of hand it would have been better to put that into a new set with better prospects. You have had transformer repairs done to it which is not a good sign; meaning that the possibility of other failures is great.
THREE: SO, lets now consider the symptoms of your set. The fact that cable channel guide data is showing on the screen means the basic video system is working. That means the power supplies and high voltage are in place.
FOUR: You could be in video input and there is no video and the set is working just fine. So, we must verify the cable box or cable wiring is giving you the right signals. The best test is to switch the tv to video in and play a vcr or dvd through the tv. If you are getting full picture and sound then the tv is likely not at fault.
FIVE: If you have another tv in the house, try connecting it to the same cable wiring to see if it receives the cable programming. If not, then the problem is wiring or cable box. If it does, then the rca may be at fault.
With these checks above you should be able to determine whether or not the tv is at fault; wiring or settings on the tv. Then take the appropriate actions. If the tv is truly at fault, you will need a repair tech to look at it, again.
You know, I have seen a case exactly like this and the problem turned out to be a short in the cable coming out of the junction box on the wall. I opened up the box and found a short against the metal box; moved the wire around and cleared it, put some insulating tape on the end of th cable and it worked just fine.
If everything is fine then the problem is with the transformer.It is blown up and u will have to call a technician to get it repaired.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 09, 2008
    President:
  • 1,944 Answers
Are you able to turn on the TV?
I got sound but no picture on my 52 inch rca floor model tv i sure its the bulbs but not sure how can i find the prices or the rite bulb for it
That set is a 1994 model set. You have 3 picture tubes in that set of which are no longer available or made anymore.
Nov 27, 2010 | RCA P56830BL 56" Rear Projection...
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
