Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak 5300 color ink error
Error says "COLOR INK CARTRIDGE EMPTY. REPLACE COLOR INK CARTRIDGE". I did that....the error won't clear from the printer.
I went online to Kodak's site to troubleshoot. It suggested removing and reinserting the cartridge. Did that. Error still won't clear.
Then is said to remove both ink cartridges and the print head. Clean with soft damp cloth. Let all dry and then reinsert. Did that and Error still won't clear.
I can't even turn it off unless I unplug it. I've tried that to see if it would recalibrate and of course not.
The other troubleshooting suggestion was to update the software/drivers/whatever technical term should be. I tried that and still no luck.
PLEASE HELP ME!!! I actually do LOVE the quality of my photos from this printer.
I appreciate your help.
We have the same problem with our 5500. This is the first color cartrigde change for this printer.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 41 Answers
The above solution might void the warenty, It might work but here is a solution that I recomend.
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGEKodak 5300 color ink error - 2.gif EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks
Posted on Feb 28, 2008
  • 983 Answers
If you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time.
Posted on Feb 10, 2008
Kodak 5350 Color Ink Error Problem Solved
Yes the cartridges of all newer printers have chip that indicates the cart ink level, when the cart is empty the chip self destructs.
May 04, 2017 | Kodak EASYSHARE 5100 All-In-One Printer
Printing with my Kodak easyshare 5300
it is necessary to install the colour cartridge.to use with black
Aug 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
My aio printer says color cartridge is empty and i have not printed anything in color, This is the 2nd color cartridge i have bought and never printed in color.
It seems that theres a problem On the printhead itself it doesnt recognized your Color cartridges., since you already purchased 2x the color ink and still it doens t recognized the color you need to call Kodak for printhead replacement toll free 1 800 421 6699.
Oct 31, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black and Color ink cartridge indicating I need to replace the ink cartridges but they are not empty. What is the problem?
It gices you a heads up warning when they get low. You will know when they get empty. The printer won't print. The color will stop when ANY of the colors run out. It protects the print head from burning out from trying to use ink that isn't there.
Aug 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 ink
First try to install a new cartridge as much as it is a waste of money. Sometimes it helps. If the error on the printer clears, download the newest firmware from www.kodak.com/go/5300downloads.
If that doesn't work, you will need to call Kodak AiO Tech Support at 1800 421 6699 to get a new printhead.
Jul 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
The Infamous Kodak 5300 "Printhead Missing or . . ." Error Message
You need a new printhead from Kodak AiO support. After that is in and you do not have the error message anymore, download the latest firmware at www.kodak.com/go/5300downloads
Jul 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE2.gif EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
Jan 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
109 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
