Question about Haier XQG50-11 Front Load Washer / Dryer
Timer inop Washer works but timer does not advance. Local repair tells me they cannot get timer.
  • Deryl Feb 09, 2008
    I need the timer for the washer part, the dryer timer works fine.
    Deryl
    Genius:
  • 3,422 Answers
Can u tell me what part you need to replace so that i can tell u the cost and from where to get it..
Posted on Feb 09, 2008
  • Priya darshan Feb 09, 2008
    Alright i got the Timer washer.
    Part# WD-7400-01
    COST- $93.99
    Click HERE to buy it
    Goodluck,
    Please don't forget
    to rate me as fixya..
Should I chuck out the cooker because the oven timer does not work?
Believe or not a lot of consumer items are this way nowadays. It sorta like push mowers where the repair parts, shipping, and labor cost as much as a replacement mower. It so expensive just get parts in from China and other places for the items they are just dumping on us that it is more cost effective to just to replace items that are out of warranty.
Oct 16, 2014 | Ovens
Maytag A512 clothes washer will not agitate, lid switch ok, will spin and pump water out, timer does not advance once washer is filled. It makes no motor sound once filled. If I manually advance the...
With the motor not coming on it sounds to me like the timer is going to be the problem and the contact in the timer for the motor to rotate in the agitate direction is burnt out. The part number for the timer is 206230 The timer could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 31, 2011 | Maytag Washing Machines
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Hello, my Frigidaire GLTF1670A Front Load Washer timer is not advancing. It will go for a little bit then stuck and runs and runs until I advance it myself. What part needs to be replaced? The timer washer...
    sounds like your timer is bad take the model to sears repair store and get a new one. make sure before that the washer do the other funtions even if you have to advance the timer. if it does then get the timer.
    Feb 05, 2011 | Frigidaire GLTF1670A Front Load Washer
    GE Top loader, Heavy Duty, large capacity washer does not advance cycles but stays in one cycle. I have to manually change cycles.
    Depending on the exact model number it sounds like you are dealing with a bad timer or bad clock on the timer. There are contact points inside the timer and they burn out. Sometimes the clock goes bad It has plastic gears inside and is non serviceable. The only thing you can do is replace the timer or call a local repair technitian to make sure.
    Oct 26, 2010 | GE Washing Machines
    The timer keeps readjusting while drying clothes, will say there is 45 minutes left and clothes are perfectly dry, this could be a fire hazard if left unattended.
    you will need to clean the vent tube/internal duct work:
    The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature then the thermostat tells the timer to begin advancing. The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
    if the vent/duct work is clogged then the
    dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry.
    I hope this helps here is a website on how to remove cabinet:
    http://www.partselect.com/dryer+amana-open-cabinet+repair.htm
    Oct 24, 2010 | Amana NED7200TW Electric Dryer
    Danby DT4229 Top Load washer. the washing mecahism
    HI. If the timer dial dose not advance, this will indicate that the timer motor has failed. Generally, this will require you to have this damaged timer mechanism replaced, asap. Unfortunately, these mechanisms are not designed to be repaired. The entire device must be replaced, if possible.
    Jan 19, 2010 | Danby DTT420 Top Load Washer
    Washer won't wash
    Hi!
    When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 30, 2009 | GE Washing Machines
    Washing Machine won't empty water during the cycle
    does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
    Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
    Timer is not working
    Mom, it sounds like a timer issue, not advancing. If your model number ends in RFS0, your part number would be 131436800. Cost of the timer is around 90.00. This is not a hard repair. Catriver..post back.
    Sep 19, 2006 | Frigidaire FWS445RF
    Open Questions:
    See all Haier XQG50-11 Front Load Washer / Dryer Questions
    Haier XQG50-11 Front Load Washer / Dryer Logo
    95 people viewed this question
    Top Haier Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
    Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
