Problem with sony vaio laptop
My laptop sony vaio will not start..when it is trurned on it does not go to the account screen it goes to the starting screen and on the corner it will say press F12 for network reboot..i goe to it and..it will say:
PXE:E61: Media test failure, check cable
PXE: MOF:Exiting PXE ROM.
A disk read error occurred
Press Ctrl + Alt + Del to restart
Also when i restart it, I would not press F12 and let it continue but it will still say Press Ctrl+Alt+Del.. would you please help me with this problem.
    Brigadier General:
  • 3,614 Answers
Your Harddisk drive did not detect by your motherboard, try to remove the IDE cable and the power cable to the harddisk and return it back and surely fit in..
tnx
-micro
Posted on Feb 10, 2008
Sony vaio desktop screen turns yellow tint soon after start up
your screen is brocken in th pixels try to change it and ready solution at your trouble coment please
Feb 02, 2014 | Sony VAIO Computers & Internet
My screen is white
Sony Vaio is one of the most prominent brands of laptops on the market, and also one of the most expensive. The laptops, created by Sony, are known for their efficient processor functionality and sleek designs. While the Sony Vaio line of laptops are considered high-end, they are also prone to display problems.
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop
Jan 28, 2013 | Sony VAIO VGN-CS204J/W 14.1" Notebook...
Sony vaio laptop half screen black on the right
Symptoms
Among the problems facing Sony Vaio laptop screens are blackouts. When these blackouts occur, the monitor turns solid black, and upon rebooting the laptop, light will briefly flash on only to blackout again. Additionally, there have been reports of an issue which causes the screen to flicker intermittently until it goes out all together. b> Troubleshooting b> Blackout displays and the continuous flickering of Sony Vaio screens can be caused by various issues taking place inside the laptop. It is not necessarily true that the problem lies within the LCD screen itself, with display issues often occurring as a result of problems with other parts of the laptop. You can test whether or not the screen is defective by connecting the laptop to an external monitor. If the display comes up normally, then the problem lies within the laptop's LCD screen. b> Parts b> If your Sony Vaio is connected to an external monitor and suddenly goes black, then the problem may have to do with the laptop's sleep button. The sleep button latch located inside the device may be jammed or broken, thus putting the screen in a permanent sleep mode until the latch is fixed. Encountering hissing sounds when the laptop is running indicates a faulty circuit board, usually damaged due to overheating. Display issues can also occur when certain parts of the laptop, such as the hard drive, have been replaced. b> Design b> Some owners have made complaints about Sony Vaio design flaws, specifically mentioning defects in the laptop's boards. Among the problems discovered after opening the laptop include burnt LCD fuses, as well as worn out circuits and internal latches. Some of these events may occur even in newly purchased units. Sony has not yet responded to various consumer complaints and has not yet issued any recalls in response to reported problems. b> Repair b> When repairing a defective Sony Vaio laptop screen, it is important that owners remain aware of the nine screws which hold the laptop cover and the board together. Not doing so can easily lead to further damage to the Vaio due to static electricity, and may even lead to a short circuit. For owners who are experienced in the area of laptop repair, parts are readily available for purchase, allowing for cost efficient repair. b> Extended desktop You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. or Click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Dec 13, 2012 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
I forgot my sony vaio e series password
Hiamaurycastil...
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 21, 2011 | Sony Computers & Internet
I have a sony vaio CS series , Flickiring screen
try to restart in safe mode by tapping f8 while restarting the computer
Select safe mode and select "safe mode"
Jul 29, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Sony vaio pcg-3c1m does not start
recharge your battery or run the laptop while being connected to the AC adapter power
Mar 14, 2010 | Computers & Internet
Power on brings the first screen "Vaio" up but then the screen goes black/blank and the "Windows XP Home Edition" page never comes up..any ideas. PS I am experienced with desktops primarily....
Before Vaio comes up, start pushing F1 or F8 or F11. If it lets you in to restore your comp, do it. That's the only way to fix this. You will lose all your files and info on your laptop though.
Jan 28, 2010 | Sony VAIO FRV27 Notebook
Black screen
have you tried checking the day time power saving settings to see if they have been incorrectly set
Aug 29, 2009 | Sony VAIO PCG-K23 Notebook
After password wlecome then blue screen,need to hole power to do anything
Dear, you system's start up files are infected or disturbed. There is one way that can help.
1. start the system.
2. constantly press and release the F8 button to get system options and select the safe mode for start up.
3. if it starts up properly into the window, just restart your system.
if not then you need to re-install the operating system on your system, becuase such problems often occur due to the worms and virsus, and it may harm you further.
Best regards.
May 26, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Windows did not start correctly
well..battery has little to do with windows starting..try it again, pressing F8 when loading up..that goes to Safe mode, where you do some troubleshooting.
May 10, 2008 | HP T2330 15.4" 250GB QP/w remote PC...
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
