Question about Car Audio & Video
My new car - well 2001 ford Ka!
Just bought a second hand car and drove it for first time out to shops to buy food today. when i came back the engine started smoking and loads of liquid has emptied into the road..! any ideas what it could be?
    New Friend:
  • 101 Answers
SWEET SMEELLING LIQUID? SMOKE? WEAT COLOR LIQ?FROM WAT AREA OR SECTION OF CAR? MORE INFO PLEASE.
Posted on Feb 11, 2008
What causes the shaking engine and bucking in gear (manual) on semi-cold start?
Check for a possible cold start injector problem or a possible motor or transmission mount that is loose or broken.
Dec 13, 2014 | 2001 Ford Mustang V6
What other Ford models have front ends that are compatible with a 2001 Ford Explorer AWD?
Never drive that vehicle without the driveshafts installed, it WILL RUIN the transfer case. Find a real mechanic to find out how much damage you did.
May 16, 2014 | 2002 Ford Explorer
Heater
Your heater control valve is faulty, these are a common fault and are mounted on the bulkhead with 2 rubber hoses and a 2 wire plug in the side. They are commonly found on ford ka and ford fiesta. A copy part can be bought from eBay for £30. Not much point in buying one 2nd hand as they commonly fail. Hope this is of help.
May 12, 2013 | Cars & Trucks
Where is the fuse for the horn on a 2001 ford ka
not sure but in most cases under the hood or on side panels on dash wich you cant see unless door is open.
Aug 12, 2012 | 2001 Ford Ka
I just bought a new 2011 Ford Escape. The second day I drove it the speedometer went from 0 - 100 just backing out of my driveway. What is happening here?
There has been a recall from Ford where the speed control engine cover is malfunctioning. Take it to your local Ford dealer and they will secure that cable @ no charge. Good luck.
Oct 29, 2010 | 2011 Ford Escape
I bought a 2001 ford ka, the car still seems to be running hot. By that i mean from a cold start is able to use the heater on full heat within a minute, the engine is getting hot really fast and the...
ford KA has the same "problem"as some other cars in as much you should "vent the topmost hot hose,after flushing or refilling the system."...with the engine running and the cap off the expansion tank.undo the clip on the topmost hot hose and allow any air to vent(wear rubber gloves, cos its real hot...)then top up the tank.
Sep 16, 2010 | Ford Festiva Cars & Trucks
My ford ka has lost power when going up hills and over 60mph
was it a second hand motor or reco one if it was a second hand motor then you may have a blown head gaskit
Aug 25, 2009 | Ford Focus Cars & Trucks
Engine management light flashes.
that usually signafies and oil change,or it just may need a tune up try both ,dont forget to replace thecoil pack while yoru at it i had one and thats about normal also the eger pipe by the ehuast likes to break as well depending on what motor you have
Feb 19, 2009 | 2001 Ford Focus
2001 Oldsmobile Bravada no heat
You may have an air bubble in your coolant system. If so, use a large coolant funnel designed to purge out air bubbles. The funnel attaches to your radiator with cap removed. Check it out on line. It costs about $25.
Nov 28, 2008 | 2001 Oldsmobile Bravada
Car Audio & Video Logo
121 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
