Question about Sony Playstation 3 (PS3) Console
Stops formatting at 99 percent
Ps3 stops formatting at 99 percent have let sit for 4 hours
  • anthes Dec 22, 2008
    I have the same problem after changing my 40GB PS3 hard disk to a 320GB Western Digital Scorpio Blue hard disk.
    Formatting stops at 99% and the the console is dead!
    Any solutions?
  • Streets77 Apr 23, 2009
    I just bought a PS3 and the first thing it wanted was updates so I let it run. At around 54% it shut down and didn't auto-restart. I started it back up and it said there was an error and it needed to format the hard drive, which I let it do. Then it raced up to 99% and hung there. I left it overnight just in case it was a long procedure and, 9 hours later it was still there at 99%.
    Any fresh ideas?
My ps3 won't show an icon for any disc that is in, it loads forever and still nothing, aparently my laser is broken, looking on the net and the problem you are having is related to the problem I have according to most people's blogs. If you still have a warranty, call the Sony customer care line on: 08705998877, I called them today, I just had to give my name address phone number and serial number on back of ps3, my new ps3 is being delivered by courier, free of charge tomorrow!
Good luck.
Posted on Feb 13, 2008
Hey guys,
i have the same problem as you with my 40gb ps3 and my WD 3200BEVT 320gb hdd. i put in my hdd and my ps3 tells me that it needs to format it. i let it do it and at 99% percent it stops but circle at the top-right is still moving.
GUYS PLEASE HELP MEEE!!!!
Posted on Jul 24, 2010
How can i install the game Rage on my PS3 slim?
It appears that you have a bad spot on your hard drive. And may need to be replaced. Sometimes shutting down improper will defect it. Static electricity will do the same thing. Format the harddrive and start over if format dose not work replace the hard drive.Have a professional do it the hard drives are delicate an can damage easily.
May 05, 2014 | Sony Playstation 3 (PS3) Console
Ps3 keeps saying restoring database it stops at 40% and after like 1 minuite it goes to 100% then it does the same thing again by saying restoring data base.
Hello
Try a router reboot.
1 power down ps3 and any pcs or laptops.
2 Unplug all cables from router.Including power for 1 min.
3 Plug all cables back in the router and power up.
4 Try ps3 again.
Another solution is some data on ps3 may be corrupt.You would need to do a restore of ps3.
You will losse all info stored in ps3 such as username passwords and accout numbers.
So write it all down if you can.
1Turn off ps3 with switch in back.
2 Turn back on,hold power button until you hear 3 beeps.
3 go through setup until prompted to format.
4 Then format.
This operation can take as long as 1 to 3 hours.Also you will loose all info you put into ps3.
Sep 22, 2011 | Sony Playstation 3 (PS3) Console
I have a ps3 but no dd i jus brought a new 40gb hdd for it and it gets to 99% formatting and wont go anyfuther,i put it in my other ps3 system and it gets to 99% and stops,any ideas?
shady_black
There might be something wrong with the harddrive. The link below will help you format the drive on your computer. If you get the same problem on your computer then the drive is bad and you will need to replace it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 15, 2011 | Sony Playstation 3 (PS3) Console
Cannot complete full format, it take more than 8 hr and at 99 % complete it stops and says "format not complete" , (it works when doing quick format but iam unable to use the drive on my ps3, and...
Welcome to Fixya. If you want to use the drive to your PS3 Console you can still do a Quick Format on the Hard Drive but make sure you select Fat32 File System type to be able for the Ps3 to detect the hard drive. Make sure you use Windows XP or Windows 7 on formatting the hard drive to Fat32 because Windows Vista dont have Fat32 it uses ExFat.
Thanks for using Fixya.
Mar 04, 2011 | SmartDisk FireLite 80 GB Hard Drive
It gets to 99% then stops loading the update
Depending on the type and exact model of the console, it is allowed to act that way on some systems. This is because the console is actually processing the last set of data that makes up the major part of the update process. As a result of this, the console takes a long time since it has to undertake more processes at this point.
All you have to do is to wait for a maximum of 10 minutes and see if there is any change or difference.
If after ten minutes, the console still doesn't work well, you would have to end the update and format the console and do the update again. Below is the instruction on how to format the console.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hope this was helpful? Please comment for more information and thank you for using Fixya.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is stuck on the system update screen on 99%. When I turn it on, it automatically goes to the system update screen. It sits at 99% for about a half hour before it gives me error code 8002f318. I've...
Your PS3 hard drive may be corrupted. Do you know, send back to game shop is too expensive and waste your time. Learn the repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only hard drive problem, you can repair other red and yellow light issues as well. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Formatting 500gb hard drive on PS3 Stuck on 99%
Well, at this point, interrupting the format process, normally a really dangerous thing to do, may be your only option, given the need to power
down the unit, for any further maintenance.
This is the kind of thing for which the reset button was made, but if reset,
given the operation of formatting a startup disk, your system may not restart.
If you have the original installation disks, be prepared to reinstall after
another attempt at formatting that which is probably a corrupt disk by now.
If you choose to attempt another format, please be careful to write down
the progress points [10% 20% 30%, etc.] for the use of the service personnel so that some estimation of the location on the disk of any damage can be estimated.
Apr 18, 2009 | Sony Playstation 3 (PS3) Console
I cant install metal gear solid 4!!!
No, it is the PS3 Network. It has been happing alot lately. Just wait a little bit, then try again in about a couple days, and it will be all set. Hope this helped.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 Won't run.
sounds like it overheated to mee -_-
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,257 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
