Question about Daewoo DVN8100N DVD Player
Won't play dvd
It just keeps trying disk but won't.
  • dragonman Feb 09, 2008
    but won't play it.
  • dragonman Feb 18, 2008
    Had tried cleaning with lens cleaner before posting problem, but no luck. Tried it again with the other three solutions, but still no luck. Put the lens cleaning disk in again and let it stay in for awhile. Finally the program for the dvd lens cleaner came up on the screen. Clicked the cleaning mode and it cleaned the lens. It now works as good as new. What step fixed it, I don't know. Thanks
    Brigadier General:
  • 6,966 Answers
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
My portable dvd player will not read any dvds
  • I would give it a good cleaning with a disk player cleaning. Those disks have little bristles on them that "sweep" the lens and clean it real well. Remember that if the lens is so dirty that it won't play any DVD you may need to run that cleaner disk a few times to get the lens back to normal working condition.
  • A lens cleaner disk should be ran one time a week to avoid problems with playing disks be it CD or DVD or Computer.
  • Sometimes players go bad so keep in mind this could be the problem as well but I have had the DVD player in my garage get so dirty I had to clean it a few times to get it to work normal.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 11, 2011 | Sylvania SDVD8732 Player
Purchased disk in of great barrier reef in Australia but won't play on my Sony SLV-D281P player...will play on my computer however.
install ashampoo ''' insert the disk and try to make a DVD rip and convert it to a kind of DVD that works on your Sony, ( DVD copies has many different formats like mpeg 1-2--3-4,flv,stch)
Jul 10, 2011 | Televison & Video
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
DVD on Curtis LD DVD 199A combo won't work in DVD mode. The DVD won't take or accept the DVD. I have never used the player before today. I did have the label to the back of the unit.
your dvd player wornt play the disk you are playing? Try to consult the region code of the player and the disk you are trying to play make sure they are of the same region..also clean the lens with a cotton buds moistened with an alcohol gently wipe it on the lens.post again if you have further question..
May 24, 2011 | Televison & Video
Won't play dvds
do you have any software that play multimedia? or Power DVD any version or is your player also cant read any dvd disk at all? why not try to clean the lens, but be careful the lens is sensitive.
May 24, 2011 | HP 5188-7537 DVD Writable CD-RW...
Can you please help me my dvd player won t play any dvd it doesnt recognize the dvd when it is inserted it keeps trying to read the dvd but it stops like it was empty
Sounds like its life is over and time for a new one. I burn a lot of disks myself and have had to replace quite a few over the yrs. You can do it yourself easy enough theres just 1 screw underneath your laptop holding it in then it just pulls straight out.....cheers and plz vote
Jan 26, 2011 | Toshiba Satellite A45-S250 Notebook
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Recorded dvd's won't play in another dvr
The problem is not the dvds themselfs it is the other play that you are trying to play them in (some players do not play DVD- and DVD+ or any other of self recorded disks) Look on the players box to see all what types of disks it can play!
Please rate answer and help keep this site free
Jan 03, 2009 | Zenith XBR716
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Daewoo DVN8100N DVD Player Logo
146 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
