Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Philips lcd flat 32 in
When we play a dvd the color is messed up when we try to adjust the color it is very difficult in fact we get frusterated and end up watching it looking terrible we bought the tv brand new last weak! Is there an easy way to adjust the color without it taking hours? Is there a normal setting we can put it on or is there someway the tv may adjust itself??? HELP!!!
    Master:
    Sergeant:
  • 440 Answers
What cable are uusing for dvd yello thats why cant use yello on these or s video go buy hdmi cable ok or reg green blue if dvd dont have hdmi outs
Posted on Feb 09, 2008
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
Incorrect color when playing DVD
Hello Mustang Cathy,
You have connection problem in Video with TV & Home Theater. This error comes mostly wrong combination of "Component Video" connections. Kindly check that one color pin must be connected with same color pin at other unit. Here is 2 pictures for further assistance. Hope problem will be solved and you will enjoy true color picture on tv.
Apr 07, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Trying to adjust my Philips TV's Custom Color Temperature
Philips 32PFL3403/12 problem with colours, after 1 hour working: starts to mix colours.
Feb 20, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
I have a Philips 32'' LCD, when I hook a DVD it plays in black and white. It will play in color in side connecter only. Please help
The side connectors are usually composite connectors meaning the have a Yellow-video Red-right audio and White-left audio connectors. Now when you are connecting them to the back and you connect the Yellow wire from the DVD player to a component input which have Green,Blue and Red connectors to the green connector, you will get a picture, but it will be in black and white. Please take moment to rate my answer. Thanks...
Nov 22, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
HDTV LCD 32 inch is all green. Good definition but all green. Have tried all color adjustments but even turning down the green all the way still leaves a green screen with some red and blue colors in the...
THe most likely cause for this problem is bad connection of the cable connecting the main TV board with the LCD controller. It's called LVDS cable and is hard to miss, usually fat round and black, connecting a board from the chasis with a little board in the top center of the LCD assembly.
I'd open the TV and gently try and reattach the cable to see if that yields any results. You can try it a few times, in fact I'd do it while the TV is open and working so I can better see if adjusting it makes a difference.
There's also a chance that the LCD logic itself got burned and misses on one of the colors. But I don't remember ever seeing that.
Nov 02, 2009 | Vizio VW32L 32 in. LCD HDTV
Black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Jul 07, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
My vizio hdtv color is off and i need help adjusting it
We had the same problem (for about a week) and finallly realized that the kids had played with the cords in the back of the TV and one connection was loose.
Mar 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
TV COLOR
your DVD is set to have S-video output (or composite NTSC or PAL - switch to tv norm that is used in your country or use SCART cable and set dvd output to RGB
hope this helps.
Sep 21, 2008 | Philips 42PFL5332D 42 in. LCD Television
Yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
Aug 18, 2008 | Philips 42PF7421D 32 in. LCD HDTV
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
