Question about HP PSC 1350 All-In-One Thermal Printer
Printer Not Printing
Message says:"Opening printer connection failed: Unable to open the printer connection. Please check your printer connections and check for printer errors." The printer already has new ink and no lights are blinking, so why can't I print anything?
  • Anonymous Feb 18, 2008
    When I click my Hp icon nothing comes up .when I try to install the printer the message reads" cannot install hardware, wizzard cannot find software "
    Guru:
  • 731 Answers
Just try the below troubleshooting steps.That will solve the Problem.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP PSC 1300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Click start - >run then type "services.msc" click OK.
8.Look for service called "Print Spooler", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
9.Right click on "Print Spooler" and click "Restart".Close the Services window and then check it.
i would appreciate, if u respond after trying the solution.
Thank you
Posted on Feb 10, 2008
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Error while printing message
Please try to powerdown your Printer and then your computer. Please restart both.
If you still are having the problem, then:
Try deleting and adding the printer again and see what happens from the printer setup utility if you are not able to print under another user and repair permission doesn't work.
Jan 09, 2008 | Brother HL-2040 Laser Printer
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
I get the error message "unable to communite with network device," yet all ports are connected and you can print from the desktop, just not from my laptop via wireless printing. It just stopped...
Hi, if your laptop is online please do check the printer status if is ready, if not remove the printer icon and try to install again the printer driver, check also the IP address of your printer or it's shared name for proper handshaking..
Jun 20, 2011 | HP LaserJet 3050 All-In-One Printer
I would love some help, because I'm not very good with computers and printers. My Canon MP830 printer has paper and ink, sounds and looks ready to go, and it will still make copies. But when I try to...
Most likely you need to install the printer drivers that came with the printer on a CD.
Or, you can download and install the very latest drivers from Canon's website!
Install them according to thier directions and you should be printing in no time!
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting ''Printer connection failed'' message
It is seen that if there are any issues with the printer drivers, issues like connection failure may occur. There are chances of drivers being outdated and corrupt. In such situations, you have to update the drivers. If there is any yellow exclamation mark next to printer driver, You need to replace that corrupted driver with the correct one. Before the installation, you also need to check for compatibility. Sometimes, incompatibility would cause issues like printer connection failed, etc.
Get more information and help to fix Printer Connection Failed . Hope this information helps you.
Jan 28, 2010 | HP PSC 1315 All-in-One Printer...
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Jan 26, 2009 | Brother MultiFunction Center MFC-440CN...
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
HP PSC 1350 All-In-One Thermal Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
