Posted on Feb 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PEAVEY AMP 1400
I'M TRY TO HOOKUP A MIXER. I WAS JUST WONDERING LEFT AND RIGHT OUTPUTS ON PEAVEY AMP OR RED OR BLACK I DON'T WANT TO HOOK IT UP WRONG THANK YOU
  • LORNE HARNUM Feb 09, 2008
    THANKS VERY MUCH DRUMMERNICK IT WAS A NEW AMP I JUST GOT
Anonymous
Level 3:
Master:
Sergeant:
  • Master 440 Answers
  • Posted on Feb 09, 2008
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
440
Questions
Helped
159732
Points
1170
Mixer 1/4 in jacks unblaced to power amp signal then to speakers red always right black left
Well I have a Peavey pv10 mixer. I'm going out of the outputs on the mixer to my amp. Then the outputs on the amp go's to my main speakers. I'm not sure where to add the powered sub. If you need more info...
The easiest thing to do is add an outboard crossover; something like a Rane AC 22S. Set the mode for stereo 2-way & mono sub out. L & R mains out from the mixer to the crossover, mono sub out to the sub and high out's to the full-range speakers.
Help with hooking up a compressor for vocals.
The compressor is a really good idea and should be connected between your mixer and your amplifiers. Your "integrated" mixer/amp is a bit tricky in that you will have to "insert" the compressor in the signal path.
If you have the "console" model....
1. "Main 1 Out" left and right to the input of your compressor and the output of the compressor connected to the "PWR Amp Insert."
2. What is known as Tip, Ring, Sleeve patch cable and plug connected ONLY to the "PWR Amp Insert." This type connection breaks out into a "Input" and "Output" using a single 1/4 stereo plug.
If you have the "square box with knobs on front" model
1. "Main Output" to input of comressor and compressor outputs to "Input to Main" (aka "AUX IN").
Check your owners manual for hookup details or suggestions and remember, all outputs feed inputs and all inputs feed outputs.
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
1helpful
3answers
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
1helpful
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Peavey 2600 Low input = Complete Cutout
I'm not quite sure of how the two amps are interacting here, so I'd like to request that you describe the entire hookup. Sending a higher signal from the mixer should not be a problem, but something is wrong in the setup (I think). Please update this with a description of how you have the mixer and amps connected to the speakers. Thanks, Dan
3helpful
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
1helpful
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
1helpful
2answers
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
 Grubhead
Grubhead
SmartAviator
SmartAviator
