Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice maker water not coming in during module cycling am able to get water by jumping L to V but nothing in auto
    Sniper:
  • 65 Answers
Are the fingers pointed toward you and slighly upward? if not replace icemaker. is the red light to the right flashing twice and then a pause? if not, replace emmitter.
Posted on Feb 16, 2008
Water pooling and freezing on bottom of freezer compartment. Where is it coming from??
If you have an ice maker in there it could be that there is too much water entering the tray and the excess spills out. OR the drain that gets rid of melted ice during the auto defrost cycle could be clogged and the water stays in freezer, pools and refreezes.
Oct 08, 2015 | Refrigerators
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
May 31, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
Kenmore elite refrigerator 10652202101 small light by ice maker on off is red flashing and water dispenser doesn't work
There is a diagnostic code you can check first of all. The blinking light will indicate the type of problem that is happening. I have included a diagnostic chart for you. To check out the ice maker there are some test points on the ice maker module that can be jumped with a well insulated wire. I have also included a picture of the test points. Before starting any of the testing first unplug the unit from the wall outlet. You will need to determine if there is 120 volts present at the ice maker module, this will require a meter. If you have access to a meter and feel comfortable doing this type of testing check between terminals L-N for 120 volts. If there is voltage there next unplug the unit again and with your jumper now jump from terminals T-H. Plug the unit back in and if the ice maker runs, after a few seconds remove the jumper and watch it go through a complete cycle. If it fills with water at the end of the cycle then the ice maker will need to be replaced. If there is no water fill unplug the refrigerator again and jump terminals L-V. Plug the unit back in and if you get water now the will need to be replaced. If there is no water fill you will need to verify if there is voltage at the water valve in back of the unit with your meter. If there is voltage there replace the valve, if no voltage that will indicate there is either a broken wire in the cabinet or a poor connection in the ice maker harness. richroth_135.jpg richroth_136.jpg
Jul 21, 2011 | Kenmore Refrigerators
My icemaker will get cold but wont make ice.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
Ice maker not making ice
always check water supply first if good pressure. you will need to start the icemaker. some will let you push start. but most roper(fsp) product requires you to jump the (T) AND (H) terinals on the frnt of the icemaker module to start. start ice maker and listen to see if solinois engages. if nothing afer a full cycle. try again and check for 12v/ac to the icemaker solinoid
Aug 01, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker Not Working
Vik, the ejector blades should be pointing toward you in the 2:00 position when the ice maker is home. This tends to make me believe that your module is bad. Pull the ice maker out again and check the center white gear. There should be 2 clips holding it on. If one of those clips broke, the gear will not rotate right. Another thing you mentioned is that you had water on the back side where the line goes into the fill tube. You may have a frozen inlet tube too. If the tube is frozen, the pressure will force it out the back by that connection. Pulling that tube out can be a pain, try using a hair dryer if the baster not working. On this model, you can't just jump T&H to start the cycle because of the immiters. Follow these instructions to start a cycle.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Dec 02, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Mar 22, 2007 | Whirlpool GD2SHGX Refrigerator
NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Nov 05, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
