Question about RIM BlackBerry Pearl 8100
Shuts off every couple of days the phone will shut itself off every time i touch it. i have to reseat the battery and then it works for a couple of days and then it does it again until i reseat the battery. it sucks
  • sunnydii Jul 07, 2008
    My Blackberry Pearl does the same thing, usually when I have it in my pocket. It is locked. I have already returned one phone within the 30 day trial and now the new one is doing the same thing. I have to re-seat the battery to get it to restart. What is causing this? Is it the on off on the top of the phone? i don't want to go thru the restore stuff you suggest as i am novice and don't want to destroy my warranty. they told me that i had to return the phone to factory if it happens again... :-| please advise if there is another update or reason for this happening.
    Thanks.
  • 97 Answers
Ive heard of this issue with windows based devices but its not as common with blackberries. you either have A) software corruption, or B) a bad battery.
to really test either is to get another battery and try it with that, if you continue to have the problem, do a master reset to free up your software corruption. you can back up the info first to avoid loosing everything, and the issue shouldnt transfer back over when you restore.
to do that, download desktop manager and go to backup and restore...select backup and save that file to your desktop.
when your done, go to options, security options, general settings, menu, wipe handheld.....type blackberry, hit the enter key. once your phone is turned on after a few mins, go back to desktop manager and then go to restore...if you continue to have an issue, youll need new software. contact your wireless provider on where to go for that....you will need their sw in order for the phone to work properly with their services.
Posted on Feb 17, 2008
I have a Blackberry Pearl 8130, the mobile network shuts off by itself. When it try to provision, the phone states that the radio is shut off. How do I fix this problem so the radio stays on all the...
This is unfortunately a known issue with the Pearl. There are a couple reasons to why this happens. If your battery is defective, then your phone will sporadically believe that your phone is low on battery (even when its not), this will cause your phone to kick the radio off by itself--even every 5 minutes. Try cleaning the battery contacts or even try a new battery. Another reason is a faulty OS, if the battery replacement doesn't work, then the problem is with your OS and will have to be re-installed. I know this sounds like a hassle, but its a known issue and it should take care of your problems.
Below is the procedure :
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
This would be a long procedure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 12, 2011 | RIM BlackBerry Pearl 8100
Phone shuts off after couple minutes.have to turn on all the time.
Hello there,
The reason the phone shuts off after a couple of minutes is simply because the battery is failing at regular intervals. First check if the phone is not set on auto shut down.
Some times if the phone works for over a while it tends to turn off itself in order to rest for a while.
Then if that is not the problem then it means the battery is not making proper contact with the metal rod in the phone.
What you need to do is to pad up the battery properly so it will seat well in the phone. That will stop the problem of the phone going off on its own.
Hope this was helpful.
Goodluck
Elect_Comp
Aug 09, 2011 | HTC Inspire 4G Smartphone
I've had the phone now for about 3-4 yrs. A couple of days ago, it started shutting off and immediately back on all by itself (rebooting), whether it's in my holder or lying on the table. The battery...
it could be more then one solution here.
maybe ur battery is low on power (irrelevant of charging)
maybe ur battery is worn out(3-4 years is quite the time)
maybe ur battery's contacs spikes are damaged (try to clean them with pure alchohol)
if it goes well, contact me!!
Apr 07, 2010 | LG VOYAGER VX10000 Cellular Phone
Nokia 95 8GB is dead
man check it with a new battery or it may b posible that ur fone s/w is crrupet which need to reinstall by a expert .
Dec 25, 2009 | Cell Phones
Phone shut itself down, won't come back on
how old is the phone and more specifically, the battery? rechargeable batteries, unfortunately, do not last forever. i used to have a phone that didn't need charging for days. over time (a few years), i had to charge every night.
will it turn on while plugged in? if so, then it's probably the battery.
Oct 22, 2009 | Samsung Jack Cell Phone
IPhone 3G shuts off by itself
Try replacing the battery. Also check to make sure that the battery itself is secure and can't move within the phone casing.
Oct 02, 2009 | Apple iPhone 3G
Lg versa shuts itself off couple of times a day
There is a shock sensor in the phone and any slight jarring will turn it off to protect the circuitry (if you drop it good)... it may be annoying but it is a decent feature.
Aug 11, 2009 | LG RUMOR Cellular Phone
PHONE SHUTS OFF SEVERAL TIMES A DAY
try taking out the battery and whiping down the coper parts of the battery and the phone. this should help. if you still have the probem go to your service provider and see if they can update your phone.
May 26, 2009 | LG KE770 Shine Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
276 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
asber
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
