Question about Toshiba SDV593 DVD Player / VCR Combo
No disc found
Hi Toshiba expert,
My Toshiba SD-V593 VCR/DVD player shows message no disc found even when there is a disc in the player. Do you have any ideas as to how I can fix this? Thank you! I appreciate your assistance.
  • KFerra Feb 10, 2008
    Thanks for your reply. However, I went and bought a cd with the fiber optic brushes and it didn't work. It read the disk for a second and then I get the message "no disc" again. If you think of anything else I could try, please let me know.
    Master:
    Sergeant:
  • 440 Answers
I would try lens cleaner cd and is this likea store rented dvd also not a copy burned one or thx nick
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    proably dirty lens buy that cd lens cleaning cd ok has fiber optic brushes on it help clean it nice also cheak cd dvd it self clean outwards witha soft tee shirt ok then try thx nick
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
After I insert the disc, the digital readout say bAd and the screen states Incorrect Disc.
There is an recall from Toshiba for "bad" problem in Toshiba SD-3980 dvd player.
"Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit. If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit."
Click Toshiba Support link for original message, please contact Toshiba and above number for replacement unit.
Hope these info will help you.
Thanks.
Feb 12, 2011 | Toshiba SD-3980 DVD Player
I have a combination dvd/vcr player. The vcr
yes its fixable.I had a panasonic recorder that did this and not very old cost me $350,00 not saying that will cost you.but sometime its better getting a new one as they have come down in price.
Jan 13, 2010 | Toshiba SD-V392 DVD Player/VCR
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
http://www.managemyhome.com/mmh/owner_manuals/search?query=Toshiba+SD-V295KU
Apr 26, 2009 | Toshiba SD-V295
Get message "incorrect disc"
One thing you can try and do is unplug the unit for 3 min and then attempt the dvds again
Oct 10, 2008 | Toshiba SD-V392 DVD Player/VCR
No disc found
Most DVD players that would not recognize and/or play a disc even with a known good disc inside signifies that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Toshiba SDV593 DVD Player / VCR Combo
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
DVD player - ERR
error in any disk i put in!!!!!!!!!
Nov 14, 2007 | Toshiba SD-V280 DVD Player/VCR
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Jun 24, 2007 | Toshiba M754 VCR
Toshiba SDV593 DVD Player / VCR Combo Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
