Question about Samsung DLP HL-P5663W 56" TV
Thin Black Vertical Lines 8 in each row, 9 rows. Whats wrong?
  • 3 more comments
  • Gene Thynge
    Gene Thynge Feb 09, 2008
    These lines are on no matter what the TV is showing Tuner, DVD player, Video game. Does anyone know whats wrong and how to fix it?.
  • Gene Thynge
    Gene Thynge Feb 10, 2008
    My TV is a Samsung DLP HL-P5663W 56".
  • SimoneV Mar 26, 2008
    My Samsung DLP HLP4663WX just started having the same problem.
  • dash8251 Oct 03, 2008
    Same problem with my 46" ( HL-S4676S ). I have read elsewhere it may be the DMD board? Wish I had a solution for this. Look forward to hearing if anyone can solve this. BTW don't think I'll be buying anymore Samsung products.
  • lauste May 21, 2009
    Similar problem but I have white vertical lines running across the screen. See pic. I hate this television. over the few years I've gone through 1 total replacement (after 3 months under warranty), 3 lamps, one new motherboard thing. And now this. Hoping I don't just have to throw it out.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Hope its under warranty! your DLP chip itself most likly is bad or If you are very lucky.. its only dust on the DLP chip,,
Time to take it to the repair man.
Posted on Feb 12, 2008
I have the line problem as well. This will be my third major repair in 3 years. 1st the bulb went, Color wheel went last month and now these black lines. Model # HLP-5063. I think this will be my last samsung purchase if I can't find simple resolution.
Posted on Aug 24, 2008
Thin red vertical line in center of my monitor AOC D2367PH
This is a clear example of a T-Con failure. Since the T-Con provides pixel clusters in lines and rows a failure would be in groups of lines and rows.
Your question is an example of an early failure; which over time will degrade to more lines & rows. I would advise replacing the T-Con board. You can do this by searching the web for your make, model and part number of the T-Con in your monitor; or if you are not technically inclined and do not want to open up the unit bring it to a TV repair technician.
Source:
http://electronicshelponline.blogspot.com/2013/06/how-to-diagnose-failed-tcon-board-how.html
Mar 06, 2015 | AOC Computers & Internet
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
My plasma tv has a vertical line across it
That is a screen defect - either a power or address line has gone out. If your set is still under warranty, exchange it ASAP. If your warranty is expired, a good repair shop may be able to fix it- be sure to get an estimate first.
This problem is only repairable if it is a wire bond outside of the screen, and I am sorry to say that chances are much higher of it being inside the screen itself, and that is not repairable.
A plasma screen is made of two glass panels with a thin gap between them, under vacuum and then backfilled with a very small amount of a rare gas mixture. The inside faces of the glass panels are silkscreened using a conductive paste, with thousands of horizontal lines on one plate and thousands of vertical lines on the other plate. The lines can be thought of as very thin, flat wires. They are addressed in a manner that where they cross one another, a plasma "pixel" is created. When a row goes out, none of the pixels in that row will work, causing a dark line. What often happens is one of these lines will crack near the seal in the panel, and then that row is lost forever.
Feb 17, 2011 | Zenith Z50P3 50 in. Plasma TV
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
On a Samsung HL-R5087W TV i have 10 rows with 8 lines per row going across the screen vertically. These lines are Black. Please HELP!!!
Single Pixel width Verical Lines in all video inputs including OSD
This is caused by a defective DMD Board
Jul 22, 2009 | Televison & Video
Two lines of 9 short stripes at the bottom end of photos
Hello sir; you need to change drum cleaning blade or drum cartridge.
Mar 24, 2009 | Dell 3100cn Laser Printer
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
977 people viewed this question
Jerry Greenberg
Jerry Greenberg
