Question about Arris SURFboard SB4200 Modem
All lights work, no connection
All the lights are working indicating that the modem is working, but the connection fades away, until I restart the modem by switching the power cord of and the back on. This happens often, maybe 10-20 times a day...
  • 1 more comment
  • Brian The Dog Feb 10, 2008
    Here's a screenshot of the logs. Hope it's enough..
    Thanks in advance!
    Hope this helps... Sorry for the trouble, and thanks again for trying!
  • Brian The Dog Feb 11, 2008
    Thank you for your quick replay! I did move my modem to another room... I'll look into it first thing in the morn ing and tell you what happened!
  • 589 Answers
Try accessing the modem itself and see what is happening on the error log.
You can do this by entering "192.168.100.1" in your browser and hitting enter.
The user name is "admin", the password is "motorola"
Then click on "logs"
The timestamps on the left of the chart are coded pretty "oddly".
For instance, mine says "080206171157" as the last entry.
This means:
08 (year)
02 (month)
06 (day)
171157 (time in 24 hour format)
Try to find one that matches a time when it dropped, and see what made it fail.
I can help you further once you get that information.
Posted on Feb 09, 2008
  • brian c
    brian c Feb 10, 2008
    These are all recent errors?
    It appears that it simply can't "hold" the signal.
    Do the same thing, but this time click on "signal" and post the screenshot.
    Sorry for all the questions, but this is the process of troubleshooting. It may be something as simple as corrosion on the connector outside, or a splitter on its way out. Once I see the signal to noise ratios, this will help me further diagnose the problem.
  • brian c
    OK, you have a line problem as indicated by the -2 dBmV downstream power level. Your upstream is within specifications.
    It is either a bad splitter, or a line problem outside. My best guess is a corroded connector by a drip loop on the wire.
    Did you recently move the modem to another room, etc?
    You have to be sure the modem is connected to the very first splitter on the line. This is crucial.
    If you are able to, try connecting the modem directly to the incoming line, with no splitters. this may be hard, as some people have splitters outside, or down in basements. A laptop will l also make this a lot easier to access the modem instead of lugging a desktop PC around. Then let the modem connect, etc, and check the power level. If the downstream power level is +5 or higher, you can rule out an outside line problem, and can start by replacing the splitter. If the power level is still in the negatives, you have an outside line problem, and you need to call your provider.
    Let me know.
Cant access Netflix on tv
hi Stephen.
Restart your home network
  • Turn off or unplug your smart TV.
  • Unplug your modem (and your wireless router, if it's a separate device) from power for 30 seconds.
  • Plug in your modem and wait until no new indicator lights are blinking on. ...
  • Turn your smart TV back on and try Netflix again.
  • Unable to connect to Netflix. Please try again or visit: www.netflix.com/help.
Troubleshooting Network Connection Issues
Dec 17, 2017 | Computers & Internet
Can't get my Netflix everything is working still have my Internet working please help
Hello
·Turn off or unplug your streaming media player.
·Unplug your modem (and your wireless router, if it's a separate device) from power for 30 seconds.
·Plug in your modem and wait until no new indicator lights are blinking on.
·Turn your streaming media player back on and try Netflix again.
For any help or support just visit us: Netflix Com Activate
Mar 30, 2017 | Netflix
Jeep liberty electrical
The battery is run down too low. When the light came on, alternator stopped working- the vehicle ran off the battery, until the lights and other electricals ran the battery down too low.
Recharge the battery, and have the alternator tested. It will probably need replacing. If you bring it into a parts store, they will test it for free.
Sep 19, 2013 | Cars & Trucks
Can't connect to the internet through the router. It worked fine until my ISP came out and changed the modem. I can connect with modem connected to Mac but not with modem connected to router.
If this is a cable modem, you need to restart the modem every time you change whatever is connected to it. Every device has a MAC address. Cable modems lock onto a MAC address that is connected to it and will only communicate with that device until you reset it by restarting. Some Comcast modems have a battery pack that must be removed in addition to unplugging it from the wall.
If it's DSL them maybe there is a username/password entered in the management console of the router.
Jun 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Internal wireless conntion is not working.
are you installed right driver software? try install again, then restart your laptop.
Sep 03, 2009 | Compaq Presario M2000 Notebook
Modem crashes, and won't work again until I power cycle
you may want your cable company to come out and check the forward signal to the modem wich could be to low , or the return to the modem  could be to low/high . one last thing is ,it could be having packet loss so severe that it drops your connection even though the modem stays linked up.
Feb 28, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Modem power adaptor
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
Oct 30, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Router not picking up i0 address
If you have cable internet then you need to :
* disconnect router from cable modem
* restart the cable modem (power off-on)
* restart the router (power off-on)
* connect cable modem to router WAN port using CAT5 straight cable
If problem still exist try changing the cable to new one. If it still does not work then contact your ISP
Jun 08, 2008 | NetGear WGR614 Wireless Router
Wireless connection
The first step to try is to reboot both the router and the cable/DSL modem. Turn off your computer, and unplug the router and the modem from the mains. Wait one full minute, then plug the modem back in. Wait until the lights stop blinking (until it indicates a steady connection). Once that is complete, plug the router back in, and wait until it also stops blinking. Once the router and modem are both back on, then turn your computer back on and check to see if you have a connection. If that doesn't work, then take the router out of the picture -- plug a computer directly into the ethernet port on the modem. You should definitely have an Internet connection at that point. If it works, the problem is in the router. If it doesn't, you'll need to call Virgin Media's help desk for assistance.
Sep 29, 2007 | Belkin (F5D9230-4) Wireless Router...
Arris SURFboard SB4200 Modem Logo
298 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
