Question about Sony PlayStation 2 Slimline Console
Reset button When i press the reset button the light does not turn from red to green and the PS2 does not work :(
  • Anonymous Feb 21, 2008
    I touched the PS and gave it a static shock. It will not turn on now. Is there a fix for this
  • sean13 Jun 25, 2008
    The red button does not go green when i press it.
Well, Prvt. Connor that maybe the reset button was damage and wire loss, I suggest you to open PS2 console and look at the reset button wire and change it if was broken or replace and clening than place it again
Posted on Feb 21, 2008
Pppppooooooppppp
    Problem Solver:
  • 6 Answers
Go to the nearest sonyworld or service centre
Posted on Feb 10, 2008
4 Suggested Answers
top50
  • 134 Answers
SOURCE: Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Posted on Nov 02, 2007
Pinhead479
  • 28 Answers
SOURCE: My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
Posted on Jan 30, 2008
SOURCE: ps2 turns itself off.
Hi, I had same problem, I just changed the fuse underneath mainboard, 3.15 Amp 120V If it doesn't work change this for 4AMP fuse
Posted on Oct 23, 2009
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
Not turning on
So, ur using the power button in the back, and then the red light turns on? Press the blue and green button on the front, and if that doesn't work, i would save up for an Xbox 360.
Apr 15, 2009 | Sony PlayStation 2 (PS2) Console
I HAVE A SLIM PS2 RED LIGHT COMES ON SHOWING HAS POWER BUT RESET BUTTON WONT TURN GREEN when I push the power button.
well first of all your only supposed to press it. dont hold down. i dont really know why, but i suppose if anything something having to do with the power cord. proud to be part of your help
-brandon
Mar 30, 2009 | Sony PlayStation 2 (PS2) Console
Guitar hereo wont work on slimline ps2
I had the same issue (since Christmas).  Today it was rainy, so I spent some time with kids and here is what worked for me
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the 'Diagnostics' menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
11) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Mar 16, 2009 | Sony PlayStation 2 (PS2) Console
We just purchased Guitar Hero and when we put it in our PS2 it dont spin the disk??
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 not spinning and light turning green then back to red
Hi
Your PS2 is probably experiencing a short circuit on the motherboard or the Emotion Engine is burned up. Sometimes the fan goes dead and the PS2 overheats and shuts down showing the red light. You can open the PS2 and clean up the motherboard and maybe it will recover.
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Changing of ps2 consol light from green to red
try to hold the red button & see if it works. if not then turn the ps2 off & try again. if it doesnt work then look for a nearby ps2 repair shop. dont go reparing over 90 pounds when you can get a new one. hope for the best, eh. GOOD LUCK!!!!
Aug 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
