Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
When I run the sweeper there is a funny smell
Every time I run the sweeper there is a funny smell, like hot plastic, too much friction somewhere. The smell leaves you thinking that something isn't right-you better stop the sweeper and check it out.
At one point we thought there seemed to be a suction problem, we checked the hoses, took off the floor metal part & took out the beater bar and cut off the yuk swirled around it (hair, thread, etc).Did NOT identify "THE PROBLEM" but the suction was fine. I think the smell may have been there before that, but definitely after that. The filter in the center of the canister and the HEPA filter a clean. The beater bar works fine.
Thanks for any help!!
  • 2 more comments
  • Stier Feb 10, 2008
    CLARIFICATION: This is a bagless model (clear canister in front) which is also beltless. Sorry, DrummerNick, that wasn't fair!
  • Anonymous Aug 14, 2008
    Vacuum was fine, changed the bag, and now there is a strong electrical "hot" smell. Vacuum is working well, suction is fine, etc, but it smells like something is burning. Vacuum is beltless.
  • aurorastar24 Aug 16, 2008
    pretty much have the same problem smell like motor burning brand new hepa turned black took apart nothing stuck no jams
  • jenp911 Nov 26, 2008
    I have the same problem. It smells so bad. I checked everything underneath, but nothing tangled in the wheels. It's beltless, so it is just driving me crazy trying to figure out what the problem is.
    Problem Solver:
  • 10 Answers
Check where the brush rotates. Pull the brush completely out and try turning the ends that are secured to the vacuum.
Posted on Jan 14, 2009
    Master:
    Sergeant:
  • 440 Answers
Cheak belt cond ?
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    maby rubing sumware
  • nick helpap
    nick helpap Feb 10, 2008
    cheak filter were goes in cloged hair ect
My Hoover wind tunnel self propelled vacuum #U6439-900 stop working. I checked the bag,filters,clean the roller and it's still not working.
Your motor may have siezed. You may have a cut in the cord somewhere too. Need more specifics to pinpoint problem. Did it stop working suddenly? Did it smoke of smell funny the last time it worked?
Nov 16, 2016 | Hoover Vacuums
Sounds funny
like what.. a whistle? a sucking sound like a gasket not seated..
Mar 06, 2014 | Rainbow Vacuums
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
Vacuim sweeper motor has a high pitch squeal otherwise runs fine
If you can notice a smell of burned rubber near the sweeper, then you most likely have a slightly stretched belt. The belt would be spinning against the beater brush, causing the squeaking noise -- as it heats up, the belt will begin to smoke, or at least give off the smell of burned rubber. This will be the most noticeable if you use the vacuum for a few minutes and then turn it off -- most times the suction from the vacuum will pull the smell into the vacuum and keep you from noticing it until it has been going on for quite some time. Replacing the belt should fix the problem.
Before going out and buying the belt, you might want to check between the belt and the beater brush -- if there is a lot of debris between the belt and the beater brush, it will cause the same type of slipping as a stretched belt, and could also be the cause of your problem. Either way, to fix the issue, you have to open the bottom of the vacuum and take a look at the belt -- if it looks to be in good shape, move it around a little. If it has a lot of room to move, it's probably stretched. If you notice a big hair clog under the belt, this is most likely to be your problem -- clean that out and you should be good to go.
May 26, 2011 | Vacuums
When using the vacum it is giving off a bad smell. We changed the bag and the filter any suggestions?
Is it a smell like burning rubber. If it is your rubber drive belt has to much stress on it and is slipping. The friction is causing it to get hot and melt.
Aug 27, 2010 | Kenmore Vacuums
Purchased a Hoover Mach 3 upright sweeper which gives off a odor
Return it immediately and run the unit with a store rep as witness.
Dec 30, 2009 | Vacuums
Sweeper smells stinks whole house up when running
Several questions:
What does the smell seem to be? If rubber, check the belt and brushroll for free rotation. If a musty smell, check the bag, it may need replaced with a new paper bag. If it has an electrical smell, like hot insulation, then the motor needs checked.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Rainbow E series
The belt looses it tensile strength (tightness) over time. But it's the part about funny sounds and shutting down that concerns me. If it smells like a tire fire then it's the belt if it smells like plastic and burned hair then the motor has a bad field or armature. Probably one of the carbon brushes got hung up and burned a segment in the armature.
Oct 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Fantom Sweeper Belt problem
Maybe it's stretched and is slipping causing friction and heat.
Try a new belt.
Mar 28, 2008 | Vacuums
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
474 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
