Question about RCA 27V514T 27" TV
Can I hook up external speakers to this T.V.?
We want to hook external speakers to this T.V. We only find input jacks on T.V. We would like to have speakers outside and/or theater sound system. Please help!
  • rbjnks Feb 11, 2008
    Thank you! We will look for the headphone jack. Not sure it has one.
  • 99 Answers
This tv carries two sound out phono plugs, but if for some reason they are not there ( date of mfr ) you can use the headphone out jack. Just go to any radio shack store and explain what you are trying to do and im sure they will be happy to assist you.
good luck,
Posted on Feb 09, 2008
Why are my channels fuzzy?
Hi Virginia,
I have the manual link for you for your TV, basically your issue falls into INPUT issue. Kindly check if the INPUT of your TV is correct. Steps below:
- INPUT SELECT button- Press to select
TV or the external input (VIDEO1,
VIDEO2) mode.
(See USING AUDIO/VIDEO INPUT JACKS.
- AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
a video camera or VCR.
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
These steps is in page 2 of the manual. Hope it helps.
Emerson EWF2004 Owner Manual Page 2 Table Of Contents
May 05, 2014 | Emerson EWF2004 20" TV
External Speakers Won't Work on Daenyx TV
1st off that is a sound input jack and what you want is what is called Headphone for that and that should solve that problem
Jan 01, 2012 | Televison & Video
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
What kind of audio system do I need to purchase for this set. The speakers are just terrible.
I changed my audio equalizer setting to "POP" and I got much more pronounced separation. Also, make sure the SURROUND is set to "ON" in your settings or simply hit the SURROUND button on the remote that came with the TV.
The "AUDIO OUT" jacks on this set apparently only work when the input is set to "TV". I wanted to hook a couple of external speakers up as well and found they would not work when hooked up to HDMI to a cable box. I mean how many people by a large flat screen like this if they don't want to view HD? Like about zero! The AUDIO OUT works only when TV is selected for INPUT
A work around is to use the headphone jack and hook a couple of external speakers up to that.
If you want to go for a higher end home theater sound bar system so that you can route both DVD and CABLE box through it via multiple HDMI's you can choose from SONY, Phillips etc.
I wrote to Sharp about the AUDIO OUT issue. It's rediculous that they only work when TV is selected for input. But you might try using the heaphone jack alternative if you find a set of speakers that sound good to you. Hope this helps.
Dec 24, 2010 | Sharp LC42SB48UT 42 in. LCD TV
How do i hook up external speakers to my sanyo plasma 42 inch hd tv
if there are jacks in the back of your sanyo you can hook up 2 speakers if your sanyo do not have external audio RCA jacks for speakers...you will need a home entertainment receiver to hook up the 2 -7 speakers...
Jun 21, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
I have a 42 inch sanyo tv I am trying to hook up saround sound or just extra speakers
Extra speakers without having the external speaker jacks in the rear is definitely a NO NO. The surround sound is used by connecting the RCA jacks from the TV that say Audio Out to the surround sound audio input on the receiver.. The RCA cables are cheap, you can get them at Home Depot ect....
Nov 27, 2009 | Sanyo Televison & Video
CAn I hook up externa speakers for the jute box Rock Ola 480
That depends if you have skp out or a head phone jack .If so the RCA out jack would
have to go to the input of your amp.
or the head phone jack could directley
drive a small set speakers , the 1/4 or 1/8
head phone jack plug wire from a old
pair of head phones would be strip and
wired to small external spk , or driectly
to the auido amp But keep the volume
on the Rock Ola very low if you
chose the latter ,as not to over drive
your amp.
for spicifics
Jul 03, 2009 | Audio Players & Recorders
No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
May 23, 2009 | Televison & Video
Which external speakers work with an Emerson 19" LCD digital TV?
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
Jan 25, 2009 | Emerson EWL20D6 Television
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
RCA 27V514T 27" TV Logo
242 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
