Question about Brother MFC 210C All-In-One InkJet Printer
INK iDON,T USE MY PRINTER ALL THAT MUCH AND SO THE INK SEEMS TO DRY OUT AT THE CARTRIGE TO INK HEAD VALVE I JUST INSTALLED A NEW BLACK , BUT THE PRINTER IS NOT TAKEING THE INK I HAVE TRIED THE CLEANING PROGRAM MANY TIMES AND TRIED A Q,TIP WITH WARM WATER ,SOME INK GOT THROUGH AND IT PRINTS BUT IT STILL READS NEAR EMPTY INK.THE INK HEAD IS NOT FILLING UP.
  • 96 Answers
Hi Shakey
If you try resetting the printer (Turn it Off and On) it will normally re-read the ink level and indicate the proper ink levels.
Please ensure you always turn your printer off by the power switch when not in use as this will allow the printer to "Park" the heads and prevent them from drying out.
If you unplug the printer, or use a powerbar the printer doesn't have the opportunity to go though its "Power Down Sequence" and ensure the heads are parked properly.
It is also recommended to use the printer (at least once a month) if not more frequently daily/weekly to ensure the heads are clean.
If you go fo long periods without changing cartridges, the cartridge itself can start to dry out, and will sometimes also contribute to clogging the heads more quickly.
Posted on Feb 09, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
After changing the cartridge the Black in is not working
Your printer's head mainly (black holes) may be block by dry ink. Try to clean it. To clean follow these proces:
Take black ink in a plastic seringe Then unplug black cartrige. See inside into cartrige carrier. There is a black plstic stick. Try it to insert into plastic seringe (carefull). Then push ink through black stick. ( 4/5 times) . After that you will be relive from your printer problem.
Thank you.
Sep 11, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer will not print in black. I put in a new black cartrige after the old one did the same thing so I know its not the cartrige itself. I used the instructions on the printer for it to clean the...
Maybe there is fault in the software and will need a re installation. so remove your printer from the PC and un-install the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | HP Officejet 5610 All-In-One InkJet...
.i used to have get good bright colored pix but
Try removing the print head again, removing the ink and re-cleaning the print head. Once it has been cleaned leave it to air dry for a few days before returning it to your printer and make sure the ink cartridges are fully clipped in. Let me know how you get on.
Mar 01, 2011 | Kodak ESP 5 Printer
My printer keeps sayon my black ink cartrige needs replacing but its a new cartrige
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 06, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer was off for a week and when turned on indicates "incorrect black cartrige installed"
Use lint free cloth and clean the contacts on cartrige and contacts on printer were the cartrige gos in. Be very gentle and very careful do not damage the contacts. Reinstall the cartrige an try again to get it to print. Do not touch the inkjet on the bottom of the ink cartrige it may distroy the print head chip on the ink cartrige and make it useless.
Sep 16, 2010 | HP PSC 750 All-In-One InkJet Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Black ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 09, 2007 | Brother DCP-340CW All-In-One InkJet...
Cleaning the print head on my HP5440 printer?
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
Nov 08, 2007 | HP Deskjet 5440 InkJet Photo Printer
Brother MFC 210C All-In-One InkJet Printer Logo
167 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
