Magnavox TV Model # PS1980 B121
All of a sudden my remote does not work on the TV - The TV works with the buttons on the set- All the functions work. Is there a way to reset the Tv to make the remote work again?
  • Dick Starner Feb 09, 2008
    Thank you
  • Dick Starner Feb 11, 2008
    Please take off your e-mail list- rastarner@earthlink.net
I solved the problem by unpluging the main power sourse and repluging. Evidently recyclining the unit! Thanks for your answer even though you were trying to get me to purchase a program! ds
Posted on Feb 10, 2008
Magnavox tv lost pause, rewind buttonstv problems
This simply sounds like a "remote address" problem, in other words--the remote is not assigned to the set. If this is for a DVD or VCR, you might have to assign that function before they work--by pressing the "dvd" or "vcr" button before they work.
Oct 02, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox tv was purchased in 2007, and now all of the sudden the remote won't even put the volume up or down and also can't change the tv settings with it,, it was working fine with the cable...
Most like the remote inner rubbers black dots tips of on those functions rubbers buttons are worn out and no more rubbers black dot tips left there any more to be connected make contact between the black dots tips to the remote PCB board.Or the remote CPU chip is shorted and dying,the CPU chip control everythings and remote devices are very dependent on it.Try website like Remotes.com to buy an original remote for the replacement.
May 10, 2011 | Philips Televison & Video
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
SDTV REMOTE CODES FOR MAGNAVOX
Hi
On the URC 4330 model the Magnavox brand is not listed in the code index.
Therefore, you should be aware that this remote may not have code stored in its pre-programmed library to allow it to operate Magnavox.
There is a code search function with this remote and this is your only other option in a situation such as this.
TO SEARCH FOR YOUR CODE FOR YOUR TV
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first so this may take some time to complete.
5.Once you find the point at which the remote operates the TV press and hold SET until the LED blinks twice, then release SET. This locks in the code.
As I say - the remote may or may not compatible with Magnavox. However this search function is there to use in situations such as this.
Hope this helps. Thanks for using FixYa.
Jan 09, 2010 | One For All URC-4330 Remote Control
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
When I push in the program little hole, a red light used to come on .
There is possibly some soda or something sticky blocking the connection. Put some 91% alcohol on a q-tip and work it around the button to break up any sticky food stuffs.
9 out of 10 button problems I see is due to Soda,Tea,Candy,Baby Saliva.
Apr 30, 2008 | Televison & Video
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
