Question about Car Audio & Video
1998 subaru legacy outback rear hatch
My rear hatch wouldn't open and i was able to pry the latch with a screw driver but it went too far and now the latch is stuck shut and the door won't close. how do i move the latch back to the open psotion?
  • 2,039 Answers
Put the kee in the lock turn the kee and hold it there in the same time use the screw driver and pull the lacht down thanks for using fixya pierre
Posted on Feb 10, 2008
Is there an access pannel under the rear seat of 1999 subaru legacy outback to access the top side fuel tank?
Yes, under the rear seat bottom on a sedan or behind the rear seat back on the panel under the carpet on the cargo area, right behind the seat back, screws hold the panel on, fuel pump right below it, easy to replace...I just did mine,1998 Legacy Wagon.
Jul 14, 2014 | 1997 Subaru Legacy
BROCKEN REAR FOLD DOWN SEAT LATCH 2011 SUBARU OUTBACK
your best option is to try unbolting the seat from the car to access the latch then pry it open with a screw driver
after its removed you will need to go though the proces to remove the seat cover and repair the release mech.
Nov 08, 2013 | 2011 Subaru Outback
How do you open a stuck rear hatch on a 1998 nissan pathfinder the latch will partially release but hatch will not open
If you can get a screw driver to try to push the latch with the screw driver. It should open. Once you have it open you need to spray it really good with WD-40. Or take it off and replace it with a new one.
Sep 29, 2010 | 1998 Nissan Pathfinder
AWD went out in my 1998 Subaru Forester?
This recently happened to my 98 Subaru Legacy Outback.
My problem is in the rear differential. May be the same for you.
When making a turn, the car sounds like a Star Wars T.I.E. Fighter. The outside wheel is not turning fast enough to keep up with the inside wheel or vice versa. AWD is disengaged and car is currently operating on Front WD. I was told this is fine to drive this way.
Jul 22, 2010 | 1998 Subaru Forester
'99 subaru legacy wagon rear hatch won't unlock
before you pull stuff, go to the back of the car. Instead of pulling the latch (away from the car and towards you) to open the hatch, push the lever in the other direction (towards the car, away from you).
i had this happen to me and read about it online, worked totally fine. It's just stuck towards you and not "sitting" correctly. Hope it works!
Dec 23, 2009 | 1999 Subaru Legacy
The hood of my 99 subaru legacy outback won't shut all the way
Had the same problem... hosed the latch down with WD40 and problem solved. I think salt and road grit build up on the latch. Same thing with the rear hatch release.
Dec 16, 2009 | 1999 Subaru Legacy
Latch for hatch of my '07 Subaru is closed with gate open
Unfortunately, you will have to remove the panel of the door, Use flathead screwdriver to pry open. It is very likely the spring fell off.
May 06, 2009 | 2002 Subaru Outback
1998 Subaru Legacy Hatch no longer opens
Most of the time these rivits break when you pull them out but sometime you get lucky. They can be bought from subaru at a cheap pruice tag. Just slip a butter knife or something of the sort under the head and pry up. Good Luck. I hope this helps. Don't forget to rate my answer.
Feb 18, 2009 | 1998 Subaru Legacy
Hatch door not opening & inside window moisture
pull the rear interior cover from the door and check to see if the latch rod clips are broken or misadjusted. the moisture could be a result of a failed heater core, poor defroster operation (A/C not working, vent door, or blower motor), or the window seal could be defective.
Nov 19, 2008 | 1995 Subaru Legacy
Car Audio & Video Logo
680 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
