Question about Toshiba TP50G60 50" Rear Projection Television
Picture goes out when floor jars the TV.
I have a 10 year old Toshiba Theaterview. When the floor is jarred a little bit, the picture diasappears...just black. The picture tries to flicker back on when jarred again. especially by the circuitboard where the video plugs from the cable box plug in.
  • 1 more comment
  • Anonymous Sep 03, 2008
    My toshiba the picture will just go black while your watching it, we still have sound but no picture. If you hit the side sometimes the picture will come back. Any suggestions?
  • mpweis27 Feb 09, 2009
    I have a similar problem. There is a black rectangular box across approx. 1/4 of the picture. It does not appear until the tv in on a station for a couple of seconds. It almost looks like a black menu box, but I can not get it to go away.
  • cluithle Apr 23, 2009
    I have the same issue, while watching tv it will go black. Sometimes if you pause the DVR it will come back on, if not you have to change the tv channel then change it back to 04 to get the cable to work. We are also getting a scratchy/fuzzy noise/screen almost like an antenna issue lately. This Theaterview is 11 years old and has worked great but now we are starting to have issues with it. Any other advise?
    Phoenix,AZ
  • Toshiba Master
  • 8,617 Answers
Check for bad solder connections around where the tuner attaches to the chassis. Look for cracks with a magnifying glass solder should appear shiny with no circular cracks.
Posted on Feb 10, 2008
Can remove bottom of dishwasher to clean kenmore 577-0
I'm a little confused about your question and dishwasher model number.... Is this an older (more than 10 years old) dishwasher? Maybe could you send a picture? Well, I THINK I know what you're talking about, and you should be able to unscrew that "knob", but you may need to get or use one of those rubber pads used to remove tough jar lids.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 24, 2012 | Kenmore Dishwashers
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
My 2003 chevy trailblazer has expierenced a soft brake pedal for the past two years. The vehicle will brake when pedal is applied however when stopped you can push the pedal to the floor. I have replaced...
Sounds like you have air in one or more brake lines. All four brake lines needs to be bled to get all air no matter how little air is in them. Recommendations use two people to do this one in vehicle one at the wheel you are bleeding. Loosen bleeder,attach a rubber tube that fits tight around fitting, get a glass jar, (I use a baby food jar) put a little brake fluid in jar so the tube doesn't **** back in air, slowly apply brake and watch air bubbles in jar, do this until no more air bubbles come out. You must do this on all four wheels to be effective. If this doesn't work there is a leak somewhere. Lines, caliper, or wheel cylinder.
Happy Motoring!!!!!!
Mar 21, 2011 | Chevrolet TrailBlazer EXT Cars & Trucks
Hi, victa 550 powercut, 10 yrs plus old, problem apart from old and used is it starts runs and dies then just when you think its gonna stop it revs up again and dies and revs and dies and revs and...
Take apart the carb and give it good cleaning maybe even but a rebuild kit if available. also disconnect tank hose from carb and empty tank into clear glass jar. Sounds like there might be some water in your gas. In the glass jar you will see a clear line of liquid at the bottom that would be water, even just a little will give these similar symptoms. Good Luck....
Mar 09, 2011 | Garden
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
JVC AV-32750
Resolder the vertical deflection output IC421. It is located about three inches to the left of the flyback transformer which is the part with the red cable going to the picture tube.
Nov 12, 2007 | JVC AV-32750 32" TV
TV turns off then on again every 5-15 minutes..help please!
It sure sounds like a solder connection opening up after the set warms up enough. If that was the problem you should be able to get it to ace up by jarring it with the palm of your hand. (Don't get carried away and hurt yourself or the set). If jarring the set gets it to cut off, I can't imagine why the repair shop couldn't find the problem. If another shop is nearby, authorized or not, you may want to give them a try. If no amount of jarring the set will get it to act up, then it could very well be not worth repair due to the amount of time that would be needed to localize the circuit that is intermittent.
Jan 24, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
320 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
