Question about Microsoft Xbox 360 Console
Xbox 360 hardware problems
    Problem Solver:
  • 13 Answers
Need to be a little more specific for any help here.
Posted on Feb 10, 2008
2 Suggested Answers
SOURCE: hardware problem
Simply you have a hardware failure with your Xbox 360. Fear not though, this is a VERY common fault and perhaps more so than Microsoft would like to admit.
The problem lies with overheating. The design of the clips that hold the equipment in place for dissipating heat away from the microchips are flawed. So when a potentially dangerous heat level is reached on this chips the console resorts to the "red rings of death" hibernating state that you're all now familiar with.
Fortunately, this problem is normally fixable. Either you can fix it yourself or if the unit is still in warranty (which is likely since the warranty was extended for exactly this fault and this fault only) you can have it fixed by Microsoft.
Solution 1 - I would avoid fixing it yourself unless it is the only option. Look up "x clamp kit" or similar on google and you should be in good hands.
Solution 2 - Provided you have not opened up your 360 and broken the warranty seal behind the faceplate you should be in luck. Go to xbox.com and sign in. Once signed in go to "Support" and then "Registration and Repair". On this page register your console by entering the serial #. Click on the now registered device for more details and you will see a summary letting you know if the device is in warranty or not. Regardless of whether it is in warranty or not select "Request a new repair" from the top right. Fill in the form making sure to select the red rings issue to yes. The next page will hopefully produce an invoice with a lovely figure of 0.00. Accept, continue and follow all steps provided. Microsoft will pay to send the device to wherever they will evaluate it and send another one back. Before sending make sure that you ONLY send the console i.e. remove hard drive, cables, controllers, memory cards.
As you can probably tell I have had to use this service and on the whole I have been very pleased. Good luck
Posted on Dec 05, 2008
Xbox 360 error E74
This is a hardware issue
E73:
I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices.
Your best bet to resolve this issue is to contact xbox. They can be reached by calling 1800 my xbox.
Aug 25, 2010 | Microsoft Xbox 360 Console
Repair ethernet card in the xbox 360
is the error message can't detect the network hardware
have you tried interchange the ends of the ethernet cables
try replacing the ethernet cables
if the problem still exist call the repair//hardware dept for xbox
Jun 06, 2010 | Microsoft Xbox 360 Console
Help me fix my xbox 360
Hello, the xbox 360 has an internal memory which is not expandable. The screen freezing and 3 red lights issue is a common error for Xbox 360 consoles when experiencing a general hardware error. These are caused by the solders for the GPU and some internal components are failing thus likely making the console not to function. Try to contact MS Xbox support for it to be fixed, if out of warranty you'll gonna have to pay $99 for repair. Cheers!
May 13, 2010 | Microsoft Xbox 360 White Console
Can I use my HP2009v computer screen with the X-Box 360 Elite
In order to make this work you need the Xbox 360 VGA HD AV cable.
Following link will give you an image of the cable itself:
http://hardware.teamxbox.com/screenshots/screen-hires/42546/Xbox-360-VGA-HD-AV-Cable/
Unfortunately you wont be able to get the highest resolution with the cable.
Here you have a list of supported resolutions:
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Nov 20, 2009 | Microsoft Xbox 360 Elite Console
Red and green lights fash on the xbox 360?????????
If red lights are flashing at all on the front of the console that indicates a hardware problem / failure. This is unfortunately very common with the xbox 360. Please call Microsoft at 1-800-4-My-Xbox
Oct 22, 2009 | Microsoft Xbox 360 Console
Guitar not working for Xbox Guitar Hero
This got to be a hardware failure with the guitar, there is no wires or some button you pressed by mistake.
Try checking out that cables are plugged in, try to switch USB port to connect on the xbox 360, or else its a hardware problem.
Mar 30, 2009 | Activision Guitar Hero III: Legends of...
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 Ethernet Connection broken
sometimes you cant run you will need to adjust your network settings call 1-800 4 myxbox they can help
Sep 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
