Question about Braun WK600 Cordless Electric Kettle
Leaking kettle cordless kettle leaks from base when boiling and continues leaking if water left in the kettle
  • 3 more comments
  • dschmidt3 Apr 10, 2008
    all the braun impressions wkx00 (eg., wk200, wk600) models begin leaking from the base after a year or two of regular use - no solution but to replace unit and proctor and gamble (which owns the braun name) discontinued manufacture of all of these as of january of 2008
    was a great product otherwise - unfortunately other units have similar or worse reviews
  • nr9876 Apr 20, 2008
    Have exactly the same problem (after 11 months using).
  • Anonymous Jul 05, 2008
    Braun WK600 Impressions began leaking after 18 months.
    Great product - I'd buy it again despite this problem.
    Does not appear fixable.
  • Bob Compton
    Bob Compton Jul 21, 2008
    I had the kettle for less than a year when it started to leak.  I took it to my local service center who said it was unrepairable.  Since it was still under warranty, they replaced it, although I had to wait several weeks for a new kettle.  I have had the second kettle for a little over a year now and IT HAS STARTED LEAKING.  Is there anyway to get Braun to acknowledge that this product has a manufacturing defect and get them to give a least a partial credit for replacement?  This is a high-end product that was not inexpensive.  I would have expected it to last longer than a year or so.
  • caribousteak May 13, 2009
    Same problem exactly.  It seems its definitely a manufacturing defect.  Sad as it is an expensive kettle and a good looking one. Don't want to get rid of it but filling it up past the half way mark and it leaks!  Braun doesnt manufacture this any more so no one will be the better off for a fix .  Too bad.
oscarn
  • 110 Answers
SOURCE: kettle shuts off before boiling?
This is caused by a defective overload switch inbuilt in the kettle, sometimes the senitivity is higher than factory settings causing it to trip and reset several times before coming to boil. probably better to put up with it than going in for a costly repair.
Posted on Sep 28, 2007
SOURCE: light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Posted on Feb 21, 2009
  • 3 Answers
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: Red light's on... but no hot water!
Just a bit of clarification; the lights and heating element are both downstream of the thermal protection ( I had mine apart and had a look). Therefore the lights would be off if the thermal protection had kicked in.
Lights on but no heat means element has a problem. Could be loose wire but more likely burnt out. If you have a tamper proof TORX bit you can take the bottom cover off and check for continuity through the element. Isolate the lights from the element so your meter is not accidentally seeing continuity through the lights.
  • 4 Answers
SOURCE: Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Posted on May 04, 2009
Leaking from base
You shouldn't use this in that condition - it's dangerous by electric shock. Is it only when water level is above any limit? Is it when water has been just boiled or also when water is cold ? I mean is it water or condensed steam?
Feb 21, 2013 | Philips HD4644 Cordless Electric Kettle
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
May 07, 2012 | Russell Hobbs RHOK3123 Cordless Electric...
Scale between the kettle and the base?
I don't particularly know the model of your kettle. There are so many out there. It sounds like the tank is leaking.
Some of these cleaning and descale agents are very powerful and corrosive. The cleaning solutions you are using may have eaten through the tank of the kettle! This is what it sounds like to me.
Check the recommendations in the instruction manual for cleaning this kettle model.
Jerry G.
May 04, 2012 | Kitchen Appliances - Others
Kettle not boiling water
Please use a multimeter and check the continuity of the power cord , now switch on and test the coils resisitance. If there is no continuity then the coil is open and the element has to be changed.
You need to contact spares dept of murphy richards.
please check the link below for spares;
http://www.espares.co.uk/search/kettles/p/1102
Sep 20, 2011 | Morphy Richards 43072 Cordless Electric...
My kettle suddenly stopped working, it still shows a red light when you go to boil the water but the water does not boil. its only a few months old so what would cause this problem
sounds as if you have a lose wire in the base or else you element has failed. Undo the bottom of the kettle and check all wires are connected to the element. If all the wires are connect i would say your element has blown.
Apr 18, 2011 | DeLonghi KBO3001 Cordless Electric Kettle
I have a Russell Hobbs kettle which is now leaking. Can it be repaired. It is several years old but still works well.
The coils of Russel Hobbs outrun the shell jar for sure as the corrosion in the kettle would have caused the leak.
The best can be to get the kettle welded with metal, use gas welding to mend up the leak and use a good grinding tool to polish off the suface.
Wash and clean/scrub well to remove all flux /dirt before you use it.
Boil water three times to discard before you use it.
You can continue to use the Hobbs.
Aug 27, 2010 | Microwave Ovens
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
Oct 25, 2008 | Faberware FCP512S Cordless Electric Kettle
Braun WK600 Cordless Electric Kettle Logo
1,092 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
