Question about HP Wireless Optical Mouse
HP Optical Mouse right click button does not work
Everything on the mouse works except the right click button. Nothing happens when you click it. I have taken out the batteries and turned off everything....but I still have the problem.
  • badcough Apr 17, 2008
    My wireless mouse has just done the same. I took the rubber ball out because it was " playing up". Then I inserted two new batteries and the mouse worked fine - except for the right-click button. Model No MSR0238B
  • 4 Answers
You just need to replace the optical mouse
Posted on Feb 11, 2008
No results from right clicking
if you can hear by ear after you click right button same sound as when you push left button, then it will be software problem.....
if you can't hear same sound, then microswitch is broken, or not in proper possition.....
if it's software problem, try to plug it into another usb port, or somebody elses computer, then you will see if problem persists also there....
if it doesn't work on another computer, then it will be mouses problem.... take it back to bookstore and ask them for refund or exchange
Mar 25, 2014 | Targus Mini Kaleidoscope Optical...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
I bought a cordless mouse Fha 3410. When I let down the left click, it acts like double click, so do not let me select objects. I need to solve this problem, since I can not work normally in any...
Hi..
Go to - Devices and Printers in Control Panel
Go to - Mouse properties and check for the Doubel click speed.. See to that it is not set to the max.
May 30, 2011 | HP Wireless Optical Mouse
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Right click of the HP optical mouse not working . for last 1 month
Normal 0 Go to Control Panel and click on the Mouse icon.
Then select the mouse button you need to program.
Hope this helps. Bud
Aug 09, 2008 | HP Wireless Optical Mouse
Hello PearlySue,
Just download the latest driver for your operating system HERE
and reinstall the driver. Once you've done that, reconnect the mouse and hopefully, it should work. If it does, it would be that the mouse is kaput and you may have to replace it. If it is under warranty, just take it back to the point of purchase and get it replaced. If not, you may have to purchase a new one. But do try the latest driver download first and see...
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Microsoft Wireless Optical Mouse
HP Wireless Optical Mouse Logo
929 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
