Question about Canon PIXMA iP4200 InkJet Photo Printer
Teddy I have not used my printer for a while and I now have lines going down by prints. I have printed 5 pictures with no change. Is there a fix for this or do I have to buy new ink cartridges. They are all still full. Thanks
  • 96 Answers
Simply run a few cleaning cycles....
5-6...make sure you don;t run out of ink after the cleaning cycles as you heads can be damaged if you try to print without ink.
Posted on Feb 09, 2008
HP LASERJET 3800 PRINTS THIN BLACK LINES ON PICTURES
that print head is clogged,
do the clean cycle shown in the manual;
new cartridge time if cleaning does not work.
all things work last week but now.
nothing new here and for sure pesky printers
and for sure not used every day. (this keep them going more reliably)
made back in 2008, so is getting long in tooth and on most this full cleaning of the whole printer is advised. ever do that?
per manual?
rtm?
https://support.hp.com/us-en/product/hp-color-laserjet-3800-printer-series/500934/manuals
Oct 09, 2017 | HP Color LaserJet 3800
Lexmark p4350
Try to align the cartridges using the Lexmark software installed on your computer to fix the problem. Please follow the steps below:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark P4300 Series folder.4. Select Lexmark Solution Center.5. Select Align to fix blurry edges. Your printer will then print a page that will align your cartridges.
Try to print your document again to verify that the problem is fixed.
Dec 27, 2011 | Lexmark P4350 All-In-One InkJet Printer
Not printing properly
Print heads need to be cleaned cause they are clogged which is why even replacing the cartridges is not fixing the problem.
If the printhead can't be cleaned then a new printer is in order.
Apr 19, 2010 | Kodak ESP 5 Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
Mar 20, 2009 | Sharp AR-M450N Copier
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
I had same prob with Epson but went into preferences/main and changed from text and graphics clicked to picture or best picture..problem solved.
Aug 26, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
old marine
old marine
