Question about Cell Phones
CELL PHONE NOT CHARGING
Just recently my phone takes about 3 days to charge a single bar. This is with a new battery and a new charger. It shows its charging when on but not when it's off like it used to,(with pic of battery on front screen showing charging). But leaving it on takes down the charge faster than it charges,lol ! I emailed verizon on this matter but have heard nothing from there 24 hr service,(or is that 24 days),whatever. Any sugjestions ?
    Novelist:
  • 123 Answers
If your phone won't charge via your computer using a USB cable or via your pickup via a car charger, will it charger via the regular travel charger (i.e., plugged into the wall)? If it won't charge that way either, then the issue is with the connection or with the battery. If you replace the battery and it still doesn't charge, then the problem is with the connection. If this is the issue, then I would suggest replacing your phone, especially if it is 2 years or older. If it is a new phone and under 12 months old, then I would suggest getting a warranty replacement from your provider. If it is older, and you don't want to replace it, then try gettin a new battery, however, if it still doesn't charge, then like I said previously, it is the connection and it would be less expensive to replace the phone then to repair the connection. Hope this helps and let me know if you need any additional information.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 11, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 11, 2008
    It will help you
    rate it as fixya
    Master:
  • 518 Answers
It would be nice to know what make and model...
But I would search google for people or forums with similar problems with that Make and Model.
Geno
Posted on Feb 10, 2008
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
When charging the phone, the battery icon flashes off and on and the phone make a sound is it charging properly
hello,
it is not supposed to make any sound when charging, if it does it means there is a problem somewhere.
it is not charging properly. try to turn off the phone and plug the charger. its supposed to bring up a light the show the battery meter and show it charging bar by bar, if it doesn't come up this way, try using the same charger on another phone to see if the charger is working. anything you detect, try to replace the battery and try again.
Jan 27, 2010 | Motorola Mobility W377 Met Silver/Pink...
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
I have a motorola v3 it shows it is charging but dosent charge ..
Get the appropriate charger for that phone you may not being charging it at all
Hope it help
Jun 25, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Unable to Charge
either reflash the phone or have the main-board replaced
Jun 15, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
K1 Problem Charging Battery
sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
Jan 13, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
328 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
