Stains on clothes
I have a Maytag A511 washer and as of recently there have been black stains on clothes. I thought maybe it was a bearing but I can't get the agitator out to look at anything. Is there a way to remove the agitator? Or could these stains even be coming from the dryer? There are no visible black spots or anything in the drum, but i read that if the seal goes bad on the bearing then water can get in and force grease out.
    Novelist:
    Champion:
  • 244 Answers
Yeah if the seal has gone even slightly then it will send grease out 1 way to check if the bearings are on there way out is pull the washer out take the back panel off and look in to see if there are any green spots on the back off the washer if there is then there on there way out another way is to place your palm on the front of washer place your fingers into the drum and pull your fingers up if there is movement then there going m8
Posted on Feb 09, 2008
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Apr 06, 2011 | Maytag Bravos MTW6600T Top Load Washer
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Get stains on clothes after been washed.. noticed on new white shirts
what kind of stains like rust color.if yes you need to call a service technician to clean the unit,not an ordinary cleaning we need to dismantle the unit to replace the oil seal and bearing if worn out,but some is just for cleaning,some unit also stains came from the liquid softener,try the cycle wash and put the heater is high level to melt some liquid softener,try for 3 time without cloth inside if this is ok after that cycle no need to call technician,do it every month as a maintainance
Dec 28, 2010 | Maytag Neptune MAH9700 Front Load Washer
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Grease stains from Maytag MAV7200AWW washer
HI! I just posted a question to "justask.com" and am having the exact same problem. I paid $9 for this answer and was happy to pay it because I now know what it is! From what I have been told, it is from the transmission in your washer and will cost at least $400 to fix it (that's just a ballpark figure... I have a Frigidaire and that was the figure I was given). So, basically, it would be more cost effective for you to purchase a new washer.
Apr 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Oil stains
Hello
Welcome to Fixya
My name is Huum,
You said, you have been getting oil stains on some of my clothes.
this means your washer has a leaking seal and oils is coming out onto your clothe.
Water is getting into the seal and bearings.
Do not waste any time. Get service out there right away.
If this is caught early you may have a chance to save a lot of money!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
Please help
are the black stains small black dots? I had this problem...result...the bearing had gone! fixable but big hassle.
I got the parts on ebay for a 1/4 of the price anywhere else was offering them for
Sep 02, 2008 | Tricity Bendix AW1400W Front Load Washer
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
Stains on clothing
Usually black oily stains are a symptom of a rear main drum bearing starting to go bad. The seal goes bad first and the packing grease will start to weep out as water gets into the bearings. Is the washer starting to get loud during any spin cycle? If so, I think your bearing is starting to go. It's not a cheap fix, either. The whole back shell of the outer wash tub has to be replaced because the bearings are molded into the plastic. I hope this is helpful in some way.
Jun 11, 2007 | Kenmore 43052 Front Load Washer
Washing Machines Logo
364 people viewed this question
Top Washing Machines Experts
