Question about RCA Thomson Digital Cable Modem (DCM305R)
Ethernet vs. usb
I have a Thomson TCB Cable modem and when I connect via the usb connection, I get a 12MBps connection. When I plug in the ethernet connection, it tells me that I have 100MBps, but that there is limited or no connectivity. Also, when I'm plugged in via the usb connection, my router won't recognize the modem.
Is there something I can do to get the modem to utilize the ethernet connection?
  • Jcraw Mar 09, 2008
    I had Comcast Cable Modem (RCA/Thomson DHG535-2) installed by their technician who used the ethernet port to connect to the internet.
    I installed the USB cable and Comcast software he left me. This frees up the Ehternet port on the Modem, so I can use for my home network .
    I use a static non-routable IP address (192.168.0.2) on my NIC. When trying to access the Internet via the USB connection, it cannot connect unless I disconnect the patch cable running from the Modem's Ethernet port to my computer (NIC).
    Problem Solver:
  • 13 Answers
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Posted on Sep 29, 2008
  • 4 Answers
I think whats happerning here is that your PC is not getting packets if you have a Win" PC go to CMD type in:
ipconfig /release
(this will cut your internet connetion off)
then do this
ipconfig /renew
(this will start your internet back up) enjoy
Posted on Nov 27, 2008
  • 61 Answers
Try unplugging modem and router, then wait 3-4 minutes. Plug modem in, wait for it to acquire signal, then connect ethernet cable to WAN port on router, then plug it in. Connect ethernet from router to PC, and turn PC on. Everything should work fine.
Posted on Feb 09, 2008
  • 38 Answers
You're wanting to plug the modem into your router via the ethernet cable, correct? I've run into cable modems that don't like to use ethernet after the USB port has been used. In cases like this, I have to do a soft reset of the modem and things usually work again. Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the power button on the modem
  4. plug back in the power
  5. count to 30 while holding the power button (the modem should be blinking a lot)
  6. release the power button and see what happens.
I am having a connection problem with the rca dhg535 modem. I have two computers and one computer only has an ethernet port and the other has ethernet and a high speed usb port. I loaded the drivers for the usb port on the one computer and I have it connected fine to the modem, everything works, but when I connect my other computer to the modem with the ethernet cord I get a no connectivity. I was wondering if there is a way to run both computers off the modem without a router.
Posted on Aug 25, 2008
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Oct 30, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Can i connect usb and ethernet at same time with siemens 4200 ?
I did not know you could do it either, but I never tried. I can see an instant work around...make them both ethernet. You surely have more than one RJ46 connection in the modem/router. I figure you had the one closest to the modem was the USB and the one further away way the ethernet cable. So like I said, they probably supplied you with a short e cable so just plug that in. Assuming of course you have an eithernet adapter in the computer closest to the modem.
Try one thing first- plug them in the way you always did, unplug the modem for a minute and plug it back in and see if it detects them the way you had it set up...reboot each of the computers after that...if it is gonna work...this is the way.
Hope this helps Tim, please leave rating, thank you kindly
May 07, 2009 | Computers & Internet
Motorola surfboard sb5101 only gives me a connection speed of 12Mbs. Can I get more?
if you use the usb cable can only be sure your connection is 12Mbps, try to use lan cable that you certainly can. I also use the usb only 12Mbps, but can I use lan cable I can be more than that
Apr 06, 2009 | Arris SURFboard SB5101 Cable Modem
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
I am trying to install a cable modem with usb and ethernet connections on a windows xp computer.
Well there are 2 ways
via Ethernet
1.) connect the ethernet from the modem to the ethernet of the computer via the cable provided and thats should basically setup and give you an ip automatically
Via Usb
2.) install the drivers that came on a cd with the model
2.) follow the onscreen instructions and connect the modem via the usb cable when it tells you to
3.) when setup is complete it will create a connect icon for you, just run it to connect
Jul 14, 2008 | Computers & Internet
Can't get modem to work if I use the USB connection
Your computer is attempting to find the network connection through your LAN port. Your best bet is to reconfigure your network settings to seek its external network connection through USB, or better still, obtain a router(I personally recommend linksys wireless/basic routers due to stability), and simply use the ethernet connection through it. While this is bypassing the initial issue, it is also saving yourself a lot of hassle when it comes to retooling the PC's settings on the USB connection.
Jun 04, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson Digital Cable Modem (DCM305R) Logo
4,699 people viewed this question
Top RCA Computers & Internet Experts
Rommel Balcita
Starnley Johnwells
Starnley Johnwells
Elise Lacoursiere
Elise Lacoursiere
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
