Question about Epson Stylus CX4200 All-In-One InkJet Printer
My epsonstylus cx4200 wont print with black ink.
I recently purchased new ink for my epson cx4200 but for some strange reason the black ink cartridge won't work. All the other colors are fine.I don't understand my prints are comming out wierd because its missing black pigment.Please help!! Also my power book g4 lab top does not want to print anything at all. everytime i click on print it wont do anything even though the the start up cd has been installed.
  • Anonymous Feb 12, 2009
    I have the same Problem. I bought this printer 4 mo ago it is junk? I have run all the test and it still wont print.Did everything epson support told me to do and there not much help.
  • 96 Answers
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Posted on Feb 09, 2008
Cx4200 does not print black
If the nozzle test doesn't print black, then no black ink is flowing.
Run a "head clean", and do the nozzle check again.
Feb 19, 2015 | Epson Stylus Office Equipment & Supplies
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Epson CX 4300 printing problem
This can happen to cartridges with attached print heads. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
White line
may be u r not using a proper cartridge. replace it with a new black cartridge. see if the problem persists.
Jun 18, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Can i print without color catridges
you do need both cartridges in and with ink or the printer will not print to prevent damage to the print heads from running dry. The printer normally uses a small amount of coloured ink to "tone" blacks but if you leave it set to Black only it won't do this and in the future you should only have to replace the black cartridge.
Chris
May 21, 2009 | Canon PIXMA iP1600 Printer
Help me with Search ''I am out of color ink but still have black ink. Do you have to have pink, blue and yellow to print. It's showing that my black ink is full but because my other ink is out it wont...
Unfortunately, many inkjet printers require all the cartridges to be present and not empty in order to print anything. An inexpensive solution would be to buy a inkjet refill kit and chip reset utility. (many cartridges are "smart" and require a reset in order for them to think they're full)
Apr 18, 2009 | Epson CX4200 Stylus Color All-In-One...
Black Ink won't print
epson printers are very picky about the ink it could be possible that the off brand ink has ruined the print head
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
331 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
