Back to:
Tags:
Dacor CM24P-1 Coffee Maker
Cm24p-1
posted by jt1043 on Feb 09, 2008
When I make coffee it comes out foamy and gross looking. What would cause foam in the coffee. I have cleaned it, I have a filter on the water supply, and the water softner in the house is on bypass. I have had repair men out to the house and they have acheived nothing.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 25, 2008
FixYa! (100)
Lilyfish
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
The foam is "crema" and is perfectly normal for unfiltered coffee and espresso, in fact it is preferred by coffee lovers. I afraid if you don't like it, you need to go back to a filtered coffee machine. Be glad that is the only "problem" your having with this machine. I've had nothing but trouble with mine.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cm24p-1:
I don't want to Accept this solution
Solution #2
posted on Mar 17, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
every coffee maker i've ever used like the meile, senseo or espresso machines do that. even my starbucks coffee looks like that at first. it should go away after just a little while, especially when stirred.
Thank You!
Can you Help with these Coffee and Espresso Makers problems?
I have a CM24P-1 that will not dump the coffee cube after...
You can here the machine and it sounds like its going to...
Dacor CM 24P  we get the error "time out filling...
the piston or the metal pole below the cup that hold the...
I have a Dacor cm24p Coffee System and the water pump went...
Loading problems.
Repair Service
Find Coffee and Esp. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
