Question about Microwave Ovens
PROLECTRIX MICROWAVE MODEL NO XB693520
MICROWAVE IS WORKING BUT NO HEAT THERE
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
If the counter is working it could be one of the switches. could also be the magnetron. but you better know how to check for leakage. by law this must be done anytime a microwave is repaired.
Posted on Feb 10, 2008
Cook temp not working
follow this steps and test with VOM. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magn
Apr 02, 2013 | Maytag MMV4184A 1000 Watts Microwave Oven
Morphy richards oven is not heating and not cooking anything
please proceed according and fix it. God bless you
Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Mar 01, 2013 | Morphy Richards Microwave Ovens
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
Aug 15, 2010 | Sunbeam SBM1000 Microwave Oven
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore microwave model 721.80033700 won't heat
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Things are not heating up in the microwave
My GE Spacemaker Microwave oven does not heat up. Every other thing works. Model JVM1640
Jul 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
