Question about Refrigerators
Repair lining of fridge
Is it possible to repair the interior lining of my dometic RM7651 fridge/freezer, as my husband was doing some diy and put a tiny hole in the back of the fridge part
  • 1 more comment
  • Moira Russell Feb 09, 2008
    Thanks very much we will try that, can we get this from a hardware shop?
    President:
  • 1,314 Answers
Depending on the size of the hole you can use white rtv silicone or white epoxy
Posted on Feb 09, 2008
I have a dometic fridge freezer model number RM2652 where can I get it repaired on the recall. I live in the Uk
go google and type in --authorized repair agents for dometic fridge /freezer equipment---
look for one close to where you are
contact the "contact us " area on the manufacturers web site
Sep 17, 2016 | Dometic Refrigerators
WE HAVE A SAMSUNG RHS1DBBP AMERICAN FRIDGE FREEZER BUT THE FRIDGE PAT DOES NOT GET AS COLD AS IT USE TO (THE FREEZER PART IS FINE) BUT WE HAVE NOTICED ICE AT THE BACK OF THE FRIDGE DOES IT NEED DE-FROSTING...
You need to buy a repair kit from Appliance DIY Repairs to solve the problem you're having. We had exactly the same fault on ours, and the kit from Appliance DIY Repairs sorted it out in no time.
Aug 14, 2010 | Refrigerators
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Fridge works fine on shore power. When turn gas
What model fridge? Sound like you have a bad 12 volt heat element or there is a possibility the board is bad but the likely is the heat element.
You can remove the cover on the circuit board and unplug the 12 volt element. Do an Ohms reading on the element. Should be 35-35 Ohms. If that is ok Turn the fridge on and with a VOM check for 12 volt power on the terminals the heat element was plugged into. If there is no power the board is bad. There is also a possibility the upper board is bad. I would start with the lower circuit board. Check for power at the heat element terminals if you have power there then I would say you need to replace the heat element. The heat element is mounted in the boiler tube and just slides uo to remove it. Good luck
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic Refrigerators
Refrigerators Logo
316 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
