Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I HAVE REPLACED THE HEATER ELEMENT AND THE PROGRAME BOARD TO DISHWASHER BUT IT WONT START TWO WASH CYCLE PROGRAME LIGHTS KEEP FLASHING
  • 549 Answers
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Posted on Feb 09, 2008
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
Clean light won't go off and cannot start another
you need to pull the dishwasher out and check your heating element.
to remove code hit heated dry and normal wash and toggle till all the lights light up and then hit cancel this should clear your code.
there is a problem with the heater or the heater curcuit
let me know how it goes
Jan 13, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My BF162 runs with the door open. I also cannot
Yup, could be that pesky door latch, or even the control panel board. This could be a case for a repair man or replacement, depending on the cost.
Sep 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My clean light is flashing....call service to check heater?
f the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
294 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
