Question about Dryers
My Maytag dryer will not run. The timer element is working perfectly. The belt seems to be in tact. All lint has been cleaned up. We have flipped the breaker switch several times. Any solutions?
  • 3 more comments
  • zdmkar Feb 17, 2008
    my maytag does not start i push on bottom and nothing happens
  • Anonymous May 26, 2008
    dryer will not start
  • Anonymous Jul 08, 2008
    I have unplugged the dryer from the outlet and when I plug it back in, it shows the same settings as when it was unplugged but still will not start. This happens to me periodically and it is annoying!!
  • Anonymous Jan 19, 2009
    SAME THING WITH ME BUT I HAVE REPLACED THERMAL FUSE TWICE
  • woporama Feb 17, 2009
    what is the chance of buying a new thermal fuse and that one goes bad or is there someting causing the fuse to fail
    Sniper:
  • 65 Answers
Sounds like the thermal fuse
Posted on Feb 17, 2008
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
My maytag dryer won't heat up
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 17, 2009 | Maytag Performa PAV2200
The dryer timer runs but the dryer does not
burned out element probably to much lint on the element and motor unplug dryer and take back off and use a vacume to vacume up all the lint and look at the element to see if they are broken they are fairly cheap .cheaperthan a new dryer also check the belt it mighjt be broken
Mar 23, 2009 | Kenmore 62622 Electric Dryer
Maytag dryer isn't heating
You never mentioned if you checked the large klixon mounted above the heater.If it is bad you will have no heat but the dryer will run. If the thermal fuse (mounted on the right hand side of the heater chamber, 2 white wires) is bad then the dryer simply will not run. If it is good then the next thing you need to check is the control thermostat mounted on the blower housing. While down there check to see if that wheel is loose. If the control thermostat is ok then you have a bad contact inside the timer. Sometimes you can clean the contacts in the timer like cleaning points on a car.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 10, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Heats intermittently
the herating element might be going bad. disconnect power, remove and inspect the heating element. look to see if its getting thin at any point. as it heats it could be seperatring and only give heat when it cools completely
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
345 people viewed this question
Top Dryers Experts
Marvin
Marvin
