Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire side by side
Its not getting cold on top of the freezer or refrigerator side I know it due to the inside fan not turning on but took it apart and the fan does work do not know what is stoping the fan from turning on if someone can help me with this question?
water running from water dispenser. refrigerator stopped running. had repairman comeand put abooster on the condenser. this lasted two wks. refrigerator is only 6 years old.
    President:
  • Frigidaire Master
  • 2,651 Answers
Booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Posted on Feb 23, 2008
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
My Frigidaire refrigerator took a huge power surge during snow storm. It burned out the relay and the defrost control. Replaced these parts but now the refrigerator is freezing on the top. Is there another...
Yes, there is a fan that distributes cold air throughout the freezer and to the refrigerator side. The fan is usually located behind an access plate near the bottom of the freezer side. You should be able to hear it if it's running. If you don't hear it, remove the access panel and look at it. If it's not turning, you will need to replace the fan motor.
Oct 16, 2009 | Frigidaire FRS26H5AS Side by Side...
Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Jun 20, 2009 | Frigidaire FRT21H8 Top Freezer...
Fridge on the Fritz
sounds as if perhaps theres a fan in the freezer, copartment that is not spinning, circulating the cold air around, or if that fan is spinning you have adefost issue,not "self defrosting so the ice is building up preventing proper circulation
Nov 02, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
To me it sounds like the thremostatic controle switch has gone bad, if the fan works seperately from the system, than the switch may be bad.
Feb 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
