Question about LG 42LC2D 42 in. LCD HDTV
Poppng sound and flashes on screen
Recently my television has been occasionally making loud popping noises. When this occurs it is often accompanied with flashes on the screen. I have recently added a Sony Blu-Ray DVD player to my system. Could this be the problem
  • kimdawnw Nov 25, 2008
    I have had LG plazma TV for about 7 months. Recently the television will make a popping noise and the image will scramble. I have seen a dirty or scratched DVD movie look the same way when attempting to play.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
The Blu-Ray will not cause this problem and in my experience the popping or arcing is coming for the ysus, zsus, or one of the buffer drive bds. When I hear this complaint it is normally not long until a loud pop is heard and the unit will go dead. Most times the ysus bd fails, sometimes the zsus bd and sometimes both.
Posted on Feb 19, 2008
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
5 year old Frigidaire top freezer works ok but makes a\poppng sound on shutdown.
Would you describe it as a popping or more like a knock sound? You may have a bad spring inside your compressor allowing the piston housing to contact the case wall of the compressor. It usually sounds like someone tapping a thick piece of steel with a hammer.
If the pop noise occurs well after the unit shuts down it may just be the liner has contracted from the cold and is shifting around, make sure it is not set too cold.
Jun 11, 2010 | Frigidaire Refrigerators
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
LG 42LC2D 42 in. LCD HDTV Logo
147 people viewed this question
