Question about GoVideo VR3930 DVD Player/VCR
Eject buttons don't work--- never really was a good product.. tells me to wait and then shuts down
  • cwr1931 Oct 04, 2008
    The problem is the 5 vdc power supply is only producing 1.43 volts. Any way to get a schematic for the power supply? cwr1931@comcast.net
    Master:
  • 518 Answers
Could be a number of things:
When eject is pressed on most vcr's the unit will try to rewind the tape a bit to make sure it is tight, there's optic sensors on the hubs to detect the movement. So...
1. A broken tape could cause it.
2. A bad belt.
3. A bad idler wheel.
4. Broken gears.
5. Bad optic device.
6. Jammed motor.
Geno
Posted on Feb 10, 2008
Windows 7 wont shut down
What happens when you try to shut it down? You can always try Pressing and Holding the Power Button until it shuts down.
If it is stalling when you go thru the normal shut down process then just wait a few minutes then press and hold the power button.
If pressing and holding the power button don't work, remove the power cord, then remove the battery. This will surely work because there will be no power source.
May 06, 2012 | Computers & Internet
How do i turn on the trio t2810c
Just called customer service about this. With the screen unlocked, press the button on the front and hold it down for 5-10 seconds until a power down window appears on the screen. Double tap the screen to turn off the player. Repeat to turn the player back on.
Dec 23, 2011 | Mach Speed Trio Audio Players & Recorders
The eject button on the DVD drive diesn't work I know about paper clips but I really don't want to do that every time I use the NEW DVD drive (it does eject through the software)
This tells me that the DVD drive is functional but the Drive tray is not opening when you push the button. This in turn shows that the button is faulty. As the drive is New you have the option to claim warranty support, I suggest you claim warranty support as soon as possible.
Take care!
damnor01
Jul 12, 2011 | Dell Xps 8300 Desktop Computer (Intel CORE...
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
The dvd player is frozen, and a dvd is stuck inside . how can I get my dvd back?
I have one that is the same way, but looks like the circuits never reset, all lights stay on. plus will not open
Nov 15, 2010 | Aiwa XD-DV370 DVD Player
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
My Dual XDM7615, will not even shut off and no buttons will work at all, it wont open or change stations and only plays radio on a station that sounds like AM,remote controll has new battery and wont even...
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Jan 24, 2010 | Dual Car Audio & Video
Durabrand model HM3817DT radio/CD player- cd eject,radio volume
Durabrand products are prone to alot of problems!!! In other mords they really ****!!!
Aug 24, 2009 | Audio Players & Recorders
Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 17, 2007 | Panasonic PV-GS150 Mini DV Digital...
Battery Problem???
Ok it takes a while but heres the solution. Slide the hold button to ON and hold down the REC button.While still holding the REC button,connect the USB port and wait for your PC to find it. Once it has found it type this link in to download Firm Ware. It may take a while but it is worth the wait.Once it is downloaded to your player EJECT!!! the player before disconnecting the USB port.Now just wait for it to format yor player and it should be working good as new again. =)
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
GoVideo VR3930 DVD Player/VCR Logo
65 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
