posted by SHAKEYY on Feb 09, 2008
does this work with onmipage 15
1 Other User Has The Same Problem
Comment by technoprat, posted on Jul 19, 2008
I have a Lexmark X2480 printer/scanner. It has successfully completed all the tests, but the scanner is ignoring Omnipage, and I can find no way to direct the scan to it. I have tried re-registering, but Scansoft just ask me to put in a different code No. although it is correct and seemed to be inittially accepted the first time.
At present the product qualifies as junk unless a way can be found to get the scanner to talk to it.
Best Solution
posted on Feb 09, 2008
Virtually any scanner will work as omnipage processes the pages that have been scanned into your computer.
It will read multiple file formates including PDF types.
Rating Locked! (?) SHAKEYY has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Brother MFC-210C All-In-One InkJet
Email this problem
Email this problem
Can you Help with these Printers problems?
Brother MFC-210C All-In-One InkJet Printer
Can't get the printer to work
The scanner is installed but I... Answer This...
Unable to clean
Unable to clean
i also encounter this problem... Answer This...
Printer wont print text and...
Hello, The printer printed an... Answer This...
faxing multiple pages
I want to fax multiple pages,... Answer This...
unable to clean
unable to clean
i followed your instructions... Answer This...
Repair Service
Find Printer Repairman Near You:
