Toshiba TV, no power, red light flashing
By the power button is a red light that is continually flashing. The TV will not turn on manually or with the remote.
  • 18 more comments
  • Mary V Feb 09, 2008
    I have had the TV unplugged all day. I just tried the solution, it did not work. The light is still flashing and the TV will not come on, manually or by remote.
  • Pragmatic Feb 11, 2008
    I have unplugged mine for 2 weeks and it still occurs.
  • tnt1230 Mar 05, 2008
    red light is flashing on the tv and will not turn on
  • drifton Mar 10, 2008
    Same as described, You can here the tv tring to come on , but no go, just get the blinking red light.
  • lenny22 Mar 18, 2008
    Same - any ideas out there?
  • paulas1970 Mar 29, 2008
    yes a phillips tv
  • perkin Apr 16, 2008
    I had this same thing yesterday. The troubleshooting secion of the manual says to unplug the tv, wait a few minutes then plug back in and try again. If it doesn't come to life call a technician. It seems that the flashing light is a code to identfy the source of the problem. In my case 5 flashes- pause- 5 flashes. It means a computer board burned out---------------------------------- $500!!!!!!!!!!!!!! ouch!!!!!!!!!!!!!!!!!!!!! The TV only cost me $850!!!!!!!!!!!!!!!
    Lambert Simnel
  • Anonymous May 28, 2008
    Sony KV-36XBR400 36" TV
  • dianefair9 Aug 06, 2008
  • lbrjack Aug 15, 2008
    Sony FD Trinitron Wega KV-34HS420 will not power on. Red light flashes 6 times between pauses. I unplugged the set for several minutes and the problem continues.
  • papsbrats Aug 24, 2008
    unpluged tv red light still flashing off and on
  • VICTORVERCHE Nov 14, 2008
    POWER BUTTON FLASHING RED BUT IT WON`T TURN ON.
  • Anonymous Nov 26, 2008
    I have a Thoshiba Plasma 42" (42HP95), 3 years old that will not turn on this morning. I was watching it last night and all was fine, this AM I tried to turn it on and the power light flashes but the TV does not ititialize at all. I unpluged it several times, held the off butten for 10 seconds hoping for a reset, but nothing works. The fan does not run either, so I surmize the power supply unit sences an overload. It does make the familiar clicking noises when it is plugged in to the power source. I have been a technition for many years, but have been retired since before Plasma units were a part of the electeronic landscape.
  • funkygirl_76 Nov 30, 2008
    same issue. Widescreen CRT Sony Wega Tv. No picture, turns itself off. Whats wrong?!!?
  • djboo1 Dec 08, 2008
    i have a thomsom 42" rear projection tv and my red light flashes when i turn it on its red then i press the on button on the remote it goes green to turn on but then turns off then it turns on again then it turns off then it just flashes red any help thanks andy
  • macdogseagul Dec 11, 2008
    power light flashes but no power
  • 72pinto Jan 21, 2009
    Same problem, 1 second interval flash.
    need repair code.
  • Anonymous Jan 23, 2009
    I have the same problem and need to find the part can anyone tell me where u can purchase the power button supplly unit?
  • Anonymous Apr 14, 2009
    Yeah, I have two toshibas that blink red when I turn them on. They just sit there blinking, nothing else. One of them requires a good smack and it turns on, the other I cannot figure out.
  • Anonymous Mar 30, 2014
    any ideas?
  • 2,322 Answers
Unplug the TV for 2 minutes and plug it back on.
It should work.
Posted on Feb 09, 2008
Need to vacuum the dust out of the top filter at the very top of the TV... build up of dust will turn off screen and start flashing light. At some point, TV will break, but this helps us solve problem
Posted on Jan 05, 2009
I have just one constant flashing red light.
Posted on Nov 17, 2008
If you pull the back off the set and look at the front left circuit board there is a small fuse there. It will probably be open. If your lucky, try another fuse and off you go. If your not lucky you have a shorted component in the power supply area of that board. Probably a voltage regulator of diode shorted. Good luck
Posted on Jun 09, 2009
This just started for me too on a Toshiba 36" crt.. I found that waiting for any amount of time didn't work for me.. I actually got interesting and repeatable results by shifting the TV around where it sits!
By moving the tv (pushing from the front right bottom) I found that I could bring it back from the flashing red light business.. moving it forward would cause the flashing red light to happen again.. implies to me that there might be a loose board or cable or solder in the tv case that is causing the fault protection to fire off.. Kinda makes sense for me since I just moved this tv from mainland to hawaii and it probably got jostled around a bunch.
Posted on Dec 18, 2008
Try this - it worked for me. Unplug the TV, unhook the cable, and let it just SIT for 24 hours. Evidently, this FLASHING RED LIGHT OF DOOM is the TV in 'standby mode'. The standby mode evidently 'times out' at 24 hours. This has happened to be twice before I finally figured it out. Wait the full 24 hours, then plug the TV set back in, hook up the cable, and turn it on using the on-set power button. From now on, use the REMOTE to turn the set on and off to avoid the TV going into standby mode. Oh......another word of advice....don't ever buy another Toshiba TV....
Posted on Nov 15, 2014
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Tv won't turn on
what remote do you have? if you have a little button called "tv" or "tv2" press one of them and then try tu turn on your TV.
Apr 07, 2010 | Toshiba 32AF43 32" TV
Rca universal remote (rcr3273) no manual- need
I don't know the exact codes but here is the search method. Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the tv turns off. Then press the stop button...and it is programmed. Thanks
Nov 01, 2009 | Televison & Video
Will not turn on...just a flashing red light
Evidently this is a common problem with Toshiba rear projection TVs. You might be able to get it working temporarily by unplugging it, pushing the power button a few times, plugging it back in, and then turning it on. Most likely your power supply is going out on you, and should be taken in to be repaired.
Temporary solution found here.
Aug 02, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 42HP95 TV turned itself off, red light blinking
has overheating issue try vacuming out the top and rear of tv. fan could be dead
Jun 02, 2009 | Toshiba 42HP95 Television
TV Won't turn on
hi
go to this site download ur tv manual and see what may be the problem hope it helps it might be kids lock or something to that effect then buttons on tv wont work until reset http://www.nodevice.com/
Apr 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Please Help Fix My TV - Toshiba 36" Model No. CF36G55
No, in answer to your question, I have not solved this problem! I am waiting to hear from someone on your site.
Thank you.
Apr 12, 2008 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Televison & Video Logo
14,756 people viewed this question
Top Televison & Video Experts
Electro Med Services...
