Question about Cyberhome CH-DVD 300 DVD Player
Player stuck and start
My player stuck (the picture freezes) and starts again. The problem gets worse further into the DVD so much so that it is a stop/start/stop/start situation. Any solution??
  • 1 more comment
  • imreadr1 Feb 10, 2008
    I hve the same problem, but my product is the Cyberhome DVR 1600 Recorder & Player.
  • Anonymous Mar 02, 2008
    same problem
  • vanb Mar 08, 2008
    I will try. Thank you.
    Scholar:
  • 104 Answers
Could be dust buildup on the laser lens. You can buy a CD-ROM/DVD lens cleaner which is a disk with fine brushes on it.
It will clean the lens of any dust/dirt. Of course, make sure your DVD's are clean also. If you're inclined you can remove the cover (with the unit unplugged) and the cover protecting the laser and carefully clean the lens directly with a q-tip. Don't press hard or use any pressure, simply wipe any dust off. Do not use any solvents on the lens as some can eat the plastic and leave it useless!
Posted on Mar 06, 2008
I have had my sumvision dvd player now for a few months and it keeps freezing periodically when watching a movie, sometimes its starts and then freezes, this is happening always now, even though I have...
The problem is the laser pickup assembly in the dvd, If it freezes the stepper motor which drives the worm gear along with the laser carriage is the problem, the precision in tracking is critical and any interference causes the picture to freeze. If you have any warranty on the unit I would encourage you to take it back for possible exchange, because it will get worse and finally become unusable.
Jan 08, 2011 | Sumvision Televison & Video
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
No disk & freezing
possible dirty or defective lens
May 31, 2010 | Oppo Digital OPDV971H DVD Player
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
Picture freezes. Only used it 4 times!
If you have not used your DVD player for a long time..the lens maybe not perfect ..or maybe if some water or nything else has entered ..this may happen..you should most probably have an warrante card..I suggest that you better show it to the authorized dealer..to make sure that your player doesnt get damaged further..ok
May 25, 2009 | Televison & Video
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Jan 21, 2009 | Televison & Video
Sa-mt1, picture freeze after ab 50 min-1h,than stops;
First of all,if you are using rental dvds, there might be scratch which your dvd player might have an issue to read it;however,if you have tried many dvds in this player and you are having this issue, it is time to move on to another dvd player.
I recommend a Pioneer dvd player.
solutiondoct
Oct 25, 2008 | Panasonic Home Theater System System
APEX DVD PLAYER
put dvd in starts, then skips to another part of the movie
Nov 26, 2007 | Televison & Video
Cyberhome CH-DVD 300 DVD Player Logo
100 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
